Changing engine coolant
Old May 29, 2013 | 06:19 PM
Red08's Avatar
Red08
Default Changing engine coolant
Is there any way to drain the block?
Old May 29, 2013 | 06:46 PM
Don-Vette's Avatar
Don-Vette
A reputable shop can do a proper flush. That you can not do in your driveway.
Old May 29, 2013 | 06:55 PM
jonesaut's Avatar
jonesaut
During maintenance at 160,000 + miles I overhauled my starter and
removed the block plug to drain the block. Happy I did it only a small
amount of junk was present. You will need a 5/16 male hex.
Old May 29, 2013 | 07:51 PM
z06clif's Avatar
z06clif
True but a bit pricey. I had mine done at the dealership and they have a machine that takes the old coolant out under pressure.
Clif
Old May 29, 2013 | 08:29 PM
Red08's Avatar
Red08
The local Chevy dealer charges $110 for flushing out the old, and putting in the new. Does this sound about right?
Old May 29, 2013 | 08:39 PM
Kvothe's Avatar
Kvothe
Old May 29, 2013 | 09:30 PM
Mad*Max's Avatar
Mad*Max
are you sure they are flushing out the old at that price (I presume includes cost of new coolant)?
Old May 30, 2013 | 07:19 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Just had mine flushed 2 weeks ago. $63 labor, $30 for "cool syst flush", and $17 for "coolant". Looks like the same $110 you were quoted. I've done coolant changes in the driveway before and $110 is worth it to me to get a proper flush.
Old May 30, 2013 | 08:46 AM
torquetube's Avatar
torquetube
Yes, there are _two_ block drains. The one you can see, a big round brass plug with a 17mm internal hex drive - and the one you can't, a conventional external hex bolt above the starter motor. You have to pull the starter, but that's easy. The big brass one is actually harder to access in practice. I use a stubby one-piece 17mm socket, Mac Tools P/N SC80.
Pretty much nobody does this because it's hard. They drain the radiator, blast water through the system to displace the other half of the coolant still in the block, and top off with coolant to arrive at the 50/50 mix ratio, more-or-less. This is a little inexact and very messy.
Old May 30, 2013 | 09:37 AM
truckplay's Avatar
truckplay
pull a radiator hose, run the garden hose into the the engine, start the car , catch the old stuff in a drain pan and run until clean. then shut the engine off, fill with coolant, top with water. then put the old stuff into containers and take it to an auto parts store for recycleing.
pay the $100 and keep it clean, but you don't know what corners those monkeys cut.
Old May 30, 2013 | 09:42 AM
wayback's Avatar
wayback
My dealer charges $175 for a change/flush. Still better than making a big mess in my driveway.
Old May 30, 2013 | 10:08 AM
Red08's Avatar
Red08
Thats what they told me that they do. It does sound a lot easier than messing with it at home, making a mess etc. I will let them do it on the condition that I can watch them do the work. If I have to sit and wait in the customer lounge, I will go elsewhere.
Old May 30, 2013 | 12:06 PM
JCtx's Avatar
JCtx
My approach is to do that when coolant is still in good shape, so just a radiator/reservoir drain and refill is necessary. Cheap, and no mess. Many car manufacturers warn against any kind of flushing. I prefer not to do that too. Good luck.
Old May 30, 2013 | 03:41 PM
obxchartercaptain's Avatar
obxchartercaptain
FL Events Coordinator
WRONG....With the anti-freeze that is in our vettes....5 yrs is the recommended change time. The Anti-Freeze breaks down and corrision can happen...even if there are NO miles on it. I just changed my 04 Silverado 4x4 with 60,000 miles for the second time and had corrosion on inside of the thermostat housing. I imagine it's inside the radiator as well. I will bring my Vert to the dealer and have him do it. 108 out the door.
Old May 30, 2013 | 04:00 PM
KoffyNut's Avatar
KoffyNut
Old May 30, 2013 | 04:09 PM
LS WON's Avatar
LS WON
Dealership here won't do it (california envionmental law?) They will only drain from petcock on bottom side of radiator and fill from coolant reservoir. No flush.
Old May 30, 2013 | 04:11 PM
LS WON's Avatar
LS WON
Amsoil claims good for 750,000 miles and suppose to be pet friendly.
Old May 30, 2013 | 06:13 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
My dealership charged me last Dec 119.85 including tax. I would say no mess at the house, plus they use machines to suck it out and service it back with no air blocks.
To Changing engine coolant
