Sometime ago someone posted a video on how to use a ateq to set or callibrate the tire pressure sensors. Does anyone have those instructions? Did a search and could not find. Thanks very much.
Below are 2 videos - one is using an ATEQ VT50 to just do some diagnostic checks on some sensors, and the other one I'm using a different TPMS tool to register the sensors into the TPMS computer in the car.
After putting the car into the learn mode, all TPMS tools would be used essentially the exact same manner as you see in the second video - just trigger each sensor in the order you see in the video, making sure that you get a honk of the horn at each wheel (double honk at the Left Rear). The honk is your confirmation that the sensor was triggered, sent out its data, and that the data was properly logged into the TPMS computer's memory.
