Evil Squeak
Old Jun 2, 2013 | 12:53 PM
BecauseRacecar's Avatar
BecauseRacecar
Cruising
Default Evil Squeak
Been chasing the infamous belt squeak for a few weeks now. Replace both belts, check pulleys, listened to each pulley with a tool, greased the tensioner and ac compressor pulley. Finally learned the problem was the harmonic balancer when it came loose today, shredded the new belt, and damaged the tensioner pulley. Hooray for owning a 2005 with the awful tsb on the balancer right?
Old Jun 2, 2013 | 02:24 PM
LUVMINE's Avatar
LUVMINE
St. Jude Donor '13-'14-'15-'16-'17-'18-'19-'20-'21-'22
If it makes you feel any better, it's been happening in other years too. Good luck with the fix.
Old Jun 2, 2013 | 02:26 PM
EVRose's Avatar
EVRose
Yep. Not just an 05 issue. That should be the first thing checked as soon as any chirping under the hood is heard.
To Evil Squeak
