DIC buttons stopped working
Old Jun 5, 2013 | 12:12 PM
ConfusedGarage's Avatar
ConfusedGarage
Default DIC buttons stopped working
Anyone had a similar issue or have any ideas?
My car is basically stuck on odometer, I cannot scroll through the other displays because my DIC buttons appear to have stopped working. It still lights up so it is getting power, but doesn't appear to be registering when I push buttons. I even took them out to check each button (none were stuck), and then plugged in a spare set of DIC buttons and that one didn't work either. Help! I'm lost. Appreciate any info on this.
Old Jun 5, 2013 | 12:26 PM
crusher1's Avatar
crusher1
Is your battery good? Sometimes when they get older wierd stuff starts to happen. Have you tried unhooking the battery and wait a minute and then hook it up again......that might reset it......good luck..
Old Jun 5, 2013 | 04:27 PM
ConfusedGarage
Thanks for the input Crusher1. I have, and actually have a brand new battery and no other issues to speak of. It's weird, maybe there is an issue at the harness near the cluster. Anyone know if there is a good way to test each pin in that harness? I am no electrical engineer, so dumb it down for me if so.
Old Jun 5, 2013 | 04:53 PM
J Vette's Avatar
J Vette
I had it happen to mine. Long story short is that the connection came loose behind the buttons In the dash.
Old Jun 5, 2013 | 05:16 PM
Seadawg's Avatar
Seadawg
Thank goodness my DIC still works!!!
Couldn't resist, been a long day....
Old Jun 5, 2013 | 06:15 PM
crusher1's Avatar
crusher1
This could be the culprit
Old Jun 6, 2013 | 12:56 AM
SunsetOrangeCreations's Avatar
From: Exhaust Commander Wireless Bi-Mode Exhaust Controllers, Innovative and advanced technology! --- Check out our website @ www.sunsetorangecreations.com
St. Jude Donor '13
Usually it is one button that is stuck in the pressed in position.
Check that all the buttons press in and come back out.
Old Jun 6, 2013 | 10:50 AM
ConfusedGarage
Do you mean at the clip/harness? I will check that again. I am sure it isn't a stuck button as mentioned and as I originally thought. I checked that and even tried a spare set of DIC buttons. I'll really check that harness connection out. Thx for the input guys, I hate when stuff doesnt function properly.
Old Jun 6, 2013 | 11:35 AM
cclive's Avatar
cclive
Maybe one of the buttons on the other side is stuck...the HUD buttons...
Old Jul 3, 2015 | 08:35 AM
vettefan84's Avatar
vettefan84
I know i.m.late here but did you find the solution to that problem? My 97 is doing the same dic buttons iluminate perfect but everytime i.press any of them nothing happens....reset button...fuel..em..options etc.....no working ...
To DIC buttons stopped working
