E-brake plastic frame
Old Jun 6, 2013 | 01:27 AM
05vettec6's Avatar
05vettec6
4th Gear
Default E-brake plastic frame
Does anyone know we're i can get plastic frame for E-brake ?
Old Jun 6, 2013 | 07:40 AM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
You can order one from a dealer, but it will come with the boot.
Old Jun 6, 2013 | 07:43 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Bad news, did search while back cause mine broke, and no luck. I had to go dealership and bought boot assembly, oh yes had to order it, cause it's not item they keep in stock. All I can say big dollars for new boot. It's very easy to replace.
If you pull the boot over the handle, you will see screw, remove the screw and the emergency brake handle will slide up, don't loose the button when it leaves the handle. Then slip old boot off, and new boot on, replace the screw and drops right on the clips. Takes 5 minutes.
Old Jun 6, 2013 | 08:19 AM
vig1116's Avatar
vig1116
Are you talking the plastic frame of the boot, that snaps into place? If so you need a new boot like previously mentioned, but its not that expensive. I just bought a 2012 boot with red stitching for $35, $45 with shipping...
Old Jun 6, 2013 | 07:52 PM
05vettec6's Avatar
05vettec6
4th Gear
I went to the dealer tried to order part but they couldn't tell me if the boot would come with plastic frame. Really don't want to spend 100bux and not get the frame lol. Vig were did you get yours from ? And do you have a part number so I'm for sure that I'm getting the right piece I need.
Old Jun 6, 2013 | 08:20 PM
vig1116's Avatar
vig1116
i got mine from parts taxi. Here are some of the part numbers for 2012 boots with different color stitching:
2012 Emergency Brake Boot
Ebony w/ Ebony Stitching - 20918843 - $29.34
Ebony w/ Yellow Stitching - 20906444 - $35.59
Ebony w/ Blue Stitching - 20906446 - $35.59
Ebony w/ Red Stitching - 20906445 - $35.59
Centennial Edition - 22773646 - $39.28
heres a thread, it's towards the bottom. There's an option for the handle and boot, and just the boot. As far as I know all the boots come with the plastic.
http://forums.corvetteforum.com/c6-s...staxi-com.html
Old Sep 28, 2021 | 10:19 AM
c6budapest's Avatar
c6budapest
8th Gear
any idea in 2021 where i can get these?
Old Sep 28, 2021 | 11:27 AM
sramzzz's Avatar
sramzzz
Found one here.
https://www.carid.com/acdelco/2013-c...SABEgIT-PD_BwE
Old Sep 29, 2021 | 08:52 AM
gdmoore01's Avatar
gdmoore01
Found just the plastic replacement piece as well. Seems these break frequently.
https://www.mamotorworks.com/corvett...ng-ring-642534
GD
To E-brake plastic frame
