Security alarm!! need help!! Now!!
Old Jun 9, 2013 | 02:54 PM
harley2's Avatar
harley2
Default Security alarm!! need help!! Now!!
Friend is stuck the car won't start & on dash yellow security light has lock on it!!
Anyone know how to reset C6 alarm??
thnaks
Old Jun 9, 2013 | 03:03 PM
FAsnakes's Avatar
FAsnakes
Veteran: Marine Corps
just have - 'your friend' use the fob to unlock..
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
thnaks
Content Theft Deterrent (CTD) Description and Operation
When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected. However, the CTD system does not affect engine starting.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door or the rear compartment is opened without first being unlocked using the keyless entry transmitter
• After a battery reconnect, if the battery was disconnected with the CTD system armed
• When the hood is opened (RPO UA2)
The components of the system are:
• Body control module (BCM)
• Remote control door lock receiver (RCDLR)
• Security indicator
• Door ajar switches
• Rear compartment lid ajar switch
• Hood ajar switch (RPO UA2)
• Intrusion sensor (RPO UA2)
• Intrusion sensor defeat switch (RPO UA2)
• Theft deterrent alarm siren (RPO UA2)
Arming the CTD System
Use the following procedure in order to arm the system:
Place the shift lever in PARK.
Turn OFF the ignition.
Open and close any door.
Lock the doors with the LOCK button on the transmitter. The system is in standby mode and will not start the arming timer until all doors are closed.
The system will begin the arm sequence immediately after the last door is closed. If the keyless entry transmitter is used to arm the system after the vehicle doors are closed, the arm sequence will begin as soon as the LOCK command is received by the transmitter. If selected through vehicle personalization, passive CTD arming may be selected.
Locking The Vehicle Without Arming The CTD System
Locking the vehicle may be accomplished without arming the CTD system. Use of the manual door locks will lock the vehicle, but will not arm the CTD system.
Disarming An Armed System/Silencing An Alarm
If system arming has occurred, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the CTD arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
To disarm the CTD system, perform one of the following:
• Press the UNLOCK button on the transmitter.
• Enter the vehicle passively with a correct key fob.
CTD Component Description
The following is a description of each component used in the CTD system:
Body Control Module (BCM)
The CTD system is an internal function of the BCM which utilizes serial data and various switch inputs to perform CTD functions. When the BCM detects an unauthorized entry, it activates the horns and exterior lamps for 30 seconds. The system will re-arm immediately following an alarm event.
Remote Control Door Lock Receiver (RCDLR)
The RCDLR receives input from the keyless entry transmitter, transferring information to the BCM via serial data. The BCM uses this information along with other information for activation and deactivation of the CTD system.
Security Indicator
The security indicator is illuminated by the instrument panel cluster (IPC) based on information, via serial data, from the BCM for CTD or from the theft deterrent module (TDM) for immobilizer. The CTD system uses the security indicator to inform the driver of system status prior to arming.
Door Ajar Switches
The CTD system uses the door ajar switches as a status indicator to activate the alarm. The BCM receives the status of the front door ajar switches based on a discrete input from each front door ajar switch. If the BCM receives a signal indicating a door is opened when the CTD system is armed, the BCM activates the alarm.
Rear Compartment Lid Ajar Switch
The CTD system uses the rear compartment lid ajar switch as a status indicator to activate the alarm. The rear compartment lid ajar switch is monitored by the BCM via a discrete input from the switch. When the CTD system is armed and the keyless entry transmitter is not used to open the rear compartment, the alarm will activate.
Hood Ajar Switch (RPO UA2)
The CTD system uses the hood ajar switch as a status indicator to activate the alarm. The BCM monitors the hood ajar switch via a discrete input from the switch. If the BCM receives a signal indicating the hood has been opened when the CTD system is armed, the BCM activates the alarm.
Inclination Sensor (RPO UA2)
The intrusion sensor is monitored by the BCM. The intrusion sensor is a motion sensor which monitors movement within the vehicle. If the CTD is in the armed mode and vehicle intrusion is detected, CTD will enter the alarm mode.
Theft Deterrent Alarm Siren (RPO UA2)
The theft deterrent alarm is a theft deterrent sounder. If the CTD System is in the alarm mode, the BCM will request the theft deterrent alarm ON.
Inputs
The BCM monitors the following inputs for CTD:
• Keyless entry transmitter LOCK/UNLOCK buttons; a serial data message from the RCDLR
• Immobilizer status--The BCM uses the immobilizer status for disarming the system or silencing an alarm when the correct vehicle key is used to start the vehicle.
Outputs
The body control module (BCM) controls he following outputs:
• The horn relay
• The exterior lamps
• The theft deterrent alarm siren (RPO UA2)
I hope something in there helps you.
Elmer
Old Jun 9, 2013 | 03:07 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Old Jun 9, 2013 | 03:16 PM
su8pack1's Avatar
su8pack1
Old Jun 9, 2013 | 04:18 PM
mcandrew67's Avatar
mcandrew67
2016 Corvette of Year
2015 C6 of Year Finalist
Tell him to put the keyfob in the slot in the glovebox I believe buttons facing right and press start.
Old Jun 9, 2013 | 07:13 PM
eboggs_jkvl
Moderator emeritus
I guess need help now was all relative to what now is?
Elmer
Old Jun 9, 2013 | 07:20 PM
michaelinmech's Avatar
michaelinmech
Elmer
I'm thinking the 'friend' must still be stuck and the little security lock light is still on, because SURELY Harley would have updated us from his panic posting . . . .
Old Jun 9, 2013 | 07:41 PM
mcandrew67's Avatar
mcandrew67
Probably went for a beer
Old Jun 9, 2013 | 07:47 PM
harley2's Avatar
harley2
No Beer! Traffic, in Pigeon Forge!
I went, to car! I think what he did was
shut it off in accessory mode!
I shut it off & on a couple time!
Then started!
Took wife out to eat!
Thanks for all the response!
Old Jun 10, 2013 | 11:00 PM
tprice's Avatar
tprice
Then started!
I am the Idiot that did this, THANKS HARLEY2
I will explain to all
I actually bough Harley2's 08 Vette Sunday, car looks like it just rolled off showroom floor and he spent a LOT of time with me going over everything
(I will post another thread bout the purchase)
Wife actually sat in drivers seat for me to take a pic to send to friends, and I told her to turn it off but she was unsure. I think she pushed the accessory button instead or this all that make sense
We tried everything and even disconnected the battery cable but that did not help
When you hit the start button all the lights and all would come on and even the radio/gps and AC fan would blow but the security light w the lock would come on and everything would go dead
Harley came to our rescue and tried a couple of things then hit the accessory button and then it fired right up.
Wife and I drove around for hour or so through Pigeon Forge/Gatlinburg and when we got back to Hotel I turned it off and on couple times and everything was great
Even stopped by drug store and got new batteries for both FOB's and could tell one I was using was getting weak and the other Harley had never taken out of the plastic bag(did I say car was PERFECT)
Thanks again for all and I am sure you will hear/see a lot of me on CF from here on out.
Love the new ride
Thanks again to all that helped us out, felt like dang idiot
To Security alarm!! need help!! Now!!
