blind spot
Old Jun 12, 2013 | 10:20 AM
jack sworcheck's Avatar
jack sworcheck
3rd Gear
Default blind spot
looking for ideas on what kind of spot mirror works the best to eliminate the blind spot on the drivers outside mirror
Old Jun 12, 2013 | 10:34 AM
Brockman66's Avatar
Brockman66
Don't waste your money on blind spot mirrors. They just look tacky and fall off. All you have do do is sit in a comfortable position in your car and adjust the mirrors so that you can just barely see your rear fenders then just move them out to where they are just out of your field of view. This, with the Corvette being as short as it is, should eliminate your blind spots.
Old Jun 12, 2013 | 10:35 AM
blitzebill's Avatar
blitzebill
I tweak/adjust both of my mirrors so that they show the blind spot area. I can still see everything I need on both sides.
Old Jun 12, 2013 | 10:37 AM
blitzebill's Avatar
blitzebill
http://www.caranddriver.com/features...id-blind-spots
Old Jun 12, 2013 | 10:39 AM
Vette_DD's Avatar
Vette_DD
Use the inside mirror to see what's behind you. Adjust both outside mirrors so that you have to stretch just a little to barely see the side of your car. Then there will no longer be a blind spot.
Old Jun 12, 2013 | 10:42 AM
blitzebill's Avatar
blitzebill
that's what I mean, my side mirrors.
Old Jun 12, 2013 | 10:43 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I actually can't see my car in my side mirrors. It felt strange to do that but it totally eliminates the blind spot as nothing can fit in that gap between the car and the inside edge of the mirror. Between the range of the rear view mirror and the side mirrors "spread" away from the car, you're fine.
Elmer
Old Jun 12, 2013 | 11:03 AM
boraxman's Avatar
boraxman
It is amazing what you can see in a correctly adjusted mirror/
Old Jun 12, 2013 | 11:09 AM
96GS#007's Avatar
96GS#007
Mirror position is one of the first things taught at various high performance driving schools. Braking hard from 130+ before diving into a turn, you don't really have time to look over your shoulder It's also one of the things that transfers from the race track to the road.
Old Jun 12, 2013 | 11:40 AM
Firewater Burns's Avatar
Firewater Burns
I dont know if "progressive mirrors" are available yet, but if you can find them, they look to optimal for automobiles. Here is what they look like, and an artical on them if you want to do some research.
Progressive Optics for Side Mirrors Ends Automobile Blind Spots without Distorting View
These images illustrate the performance between the aspheric and progressive mirror (top) and the flat and progressive mirror (bottom).
Old Jun 12, 2013 | 11:50 AM
truckplay's Avatar
truckplay
you can buy those little discs at auto parts stores and stick them on the mirrors but I think they look silly.
Old Jun 12, 2013 | 12:03 PM
phileaglesfan's Avatar
phileaglesfan
Also a quick look over your shoulder helps.
Old Jun 12, 2013 | 12:42 PM
Vette_DD's Avatar
Vette_DD
Actually, I was agreeing with you. I just left off the
I knew what you meant.
Old Jun 12, 2013 | 03:27 PM
Johnathon59's Avatar
Johnathon59
Wait till the comments start flowing about "Blind spots" with the '14 Vette !! have not even sat in one yet but with the diminished rear window I see problems already.
Old Jun 12, 2013 | 03:36 PM
MelAnn's Avatar
MelAnn
Should be no blind spots with the top down!
Bat Man's Avatar
Bat Man
I really like Ford's blind spot mirrors. I think they should be stock on ALL vehicles.
Old Jun 12, 2013 | 06:22 PM
Ferocious C6's Avatar
Ferocious C6
How to adjust mirrors properly:
For the driver side: put your head against the window, adjust the mirror to the point where you can no longer see the side of the car.
Passenger side: lean your head into the middle of the car, do the same.
Boom.
To blind spot
Old Jun 12, 2013 | 07:34 PM
dvilin's Avatar
dvilin
Old Jun 12, 2013 | 07:48 PM
okie08vette's Avatar
okie08vette
Great info on how to adjust the mirror's sad to say that I did not know this already but you learn something new everyday. I am goint to try it next time I get in the car.
Old Jun 12, 2013 | 07:55 PM
Suprpig's Avatar
Suprpig
Rule one... go fast and never look back it is behind you and no longer important.
Seriously... not that rule one doesn't really apply... but I always adjust rear outside mirrors to be slightly wider in view then the rear fenders. Why... because if you drive at night the headlights from those behind won't blind you and take away your night vision. I always say I do my best work in the dark! My avocation.
