I am seeking forum wisdom for a flat tire on my 427 vert. It only has 500 miles on it but got in the other day and had a "Left rear tire flat" warning on the DIC. I checked the pressure and sure enough it was only 5 lbs. I filled it to 30 and did the best I could to check for leaks, but couldn't find any. I took it for a ride and came back and checked it a few hours later and it was down to 25 so I guess there is a slow leak. Question is, is it better to lift the car, remove the wheel/tire and bring it to a good tire place to check it out so they don't have to lift the car and possibly damage it, or do you think I should just fill the tire and drive the car a few miles there? I haven't had a flat in forever and certainly never one on any of my Vettes, so not sure what's the best but that's what this forum is all about! Thanks in advance.
I would take it to a dealer, that tire is under warranty, they may have to replace it. Fill it with air again and drive it in, are you close to a dealer?
Just take it to a dealer. I have no worry with my dealer concerning the wheels/tires. As the service manager told me, he is not paying to replace another Corvette wheel but the customer won't be either. He allows his mechanic to take his time though.
The local Firestone dealer would be the last place I go.
If it's a slow leak in all likelihood it has a nail or screw in it. If you can elevate the tire it would be easier to look for the nail. There may be no need to remove it if you find the culprit nor will the repair place have to remove it. If it is a bad valve stem or something worse on the tire needless to say it will have to be removed and fixe which is why I suggest you look for the cause first, if you can't find it then maybe it would be worth removing yourself for "safety" reasons. And if it is a nail let them plug it, those gooey leather plugs heat up and seal great! GOOD LUCK...
Check your tire warranty in the manual package....
My '08 came with a Goodyear tire warranty when I took delivery. Look for it in your manual package or glove box.
With only 500 miles, your tire should be warranteed even if it is unrepairable damage, as was mine way back when, and Goodyear will replace the tire. If it is repairable, that would also be covered.
Also, check with the dealer that you trust (if any) to see if they will either repair it or honor the Goodyear warranty. The answer is "probably not", you will probably need to go to a Goodyear dealer. Take the warranty with you, most Goodyear dealers have no idea about it and will probably have to call the main office to figure it out.
This may not be necessary for your "slow leak", which is probably repairable. My flat was a 1 1/2" by 1/2" tear in the tread by a piece of metal, and the tire had to be replaced.
I had a slow leak in one of my 07s tires. It was the valve stem. I am not sure if the nut at the base was loose or if the schrader valve was loose. You might want to check both before doing anything. A little soapy water sprayed around the valve stem should tell you. That would be an easy fix. If not, I suggest taking it to the dealer as well. It's under warranty and they should easily be able to handle that job.
Best Luck!!!
My new 2013 did not come with a tire warranty card. In the warranty manual it spells out the tire warranty including how they will pro-rate based on mileage. The tires are included in the 3/36 warranty. At least that's how I read it.
Yep, tire is under warranty. Bring it to dealer. If it wasn't I would just bring the wheel in to a tire shop.
Unless you live in a place where there lots of tire shops with experience handling run flat tires I wouldn't go near a tire store. I have two dealers within a 10 mile radius that can work with run flats. The nearest qualified tire store is a GY store that is 20 miles away. My local GY store won't touch them and none of the other tire stores have the proper equipment or experience (I would have to drive 7 hours to get to the nearest Discount Tire location).
Depending on how far you need to drive it is your choice whether or not to put air in the tire. The stock tires can be driven 50 miles at 55 mph without any air and still be repairable.
Thanks for all the replies. I actually called the dealer and they reminded me I also bought a separate tire/wheel warranty (forgot about that) and I could call to find an authorized center to fix it, so I am going to call and see if there is anyone local that can handle the run flats. Thanks again!
The dealership for sure, one is they have the proper lifts, two they have the machines to break tire down without damaging wheels, and the balancer which has force variations.
When I worked the service dept, our machines could do anything and not damage wheel, and those machines aren't cheap. We had better then any tire store could afford.
Thanks Don, I'll check when I get home. Is the glove box the area between the seats or that cubby above the passengers knees where I keep my gloves? LOL
Bill
WOW !! 7 hour drive to the nearest Discount tire,(about 450 miles) I have 2 of them within 5 miles of my house, I should recommend one move to your neck of the woods to lessen the competition. **
Since you have warranty coverage, that would be the best route to take.
My experience (with Michelin tires) at the local Firestone store has been excellent. I'm sure it varies by location. Some places still don't know what TPMS is.
