Trunk release
Old Jun 14, 2013 | 07:09 PM
Ninjacga's Avatar
Ninjacga
Default Trunk release
My C6 trunk release won't open....using the button in the car or on my fob....only if I put the key in under by the plate??
Any ideas?
Old Jun 14, 2013 | 07:32 PM
Wildmanht's Avatar
Wildmanht
What about the button in the back above the license plate? Could be a fuse.
Old Jun 14, 2013 | 07:38 PM
chevy7398's Avatar
chevy7398
Its probably full of sand and grit and stuck. Theres a DIY on how to take it out and apart to clean it. I have to do mine about once a year. Never mind. I missed the part about not working from the dash.
calemasters's Avatar
calemasters
Check to see if you have +12v at the release motor when the button on the dash is pressed. If you do, you may have a bad release motor. If not, you may have an open circuit some where.
Old Jun 14, 2013 | 09:11 PM
speedraider's Avatar
speedraider
fuse
Old Jun 14, 2013 | 09:30 PM
BEZ06's Avatar
BEZ06
Any ideas?
with speedraider!!
Here's a picture of the fuse blocks in the passenger footwell:
Here's a picture with the covers removed from the sub-panels:
I looked in your profile and it appears that you have a convertible. The convertibles and early Z06's have a manual latch. The other coupes and Z06's built after about 2010 have an auto pull down latch. I took these pictures when I was installing an auto pull down latch into my 2006 Z06.
In a convertible or an early Z06, you'll see panels exactly like in the pictures.
What you're interested in checking is the blue 15amp fuse in the sub-block under the cover to the right of the main fuse block that I have a circle around.
If that fuse is blown then you'll have exactly the problem you're experiencing.
If the button above the license plate is dirty and not working, usually the button in the cockpit will still work - unless the sticky button blew the fuse, then nothing but the key will open the trunk.
Good luck!!
Bob
Old Jun 15, 2013 | 08:51 PM
u4magic's Avatar
u4magic
also, if it just pops open slightly, you can buy a spring from Corvette Mods that can help :-)
To Trunk release
