Battery under load?
Old Jun 16, 2013 | 12:04 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Default Battery under load?
I post this:
>> FOB not detected checklist <<
whenever a FOB mystery appears on here. The chart asks for the voltage to be checked.
What are the best methods (short of a real load testing tool) to have a car owner load test the battery and read the voltage.
I believe for a manual transmission, simply pushing the start button without depressing the clutch will give the "load" reading. If this is correct, fine if not, then state the procedure. Since I don't do automatics, what is the procedure to get a battery under load on one of those.
Keep it short and sweet as I will further chop it down and add it to my checklist as part of the instructions.
TIA
Elmer
Old Jun 16, 2013 | 12:43 PM
cclive's Avatar
cclive
I'm not sure I understand the question Elmer. The only load that really matters is the starter motor...it is hundreds of amps of load. A bad battery can many times stand up to the load of turning the ignition on, which is perhaps only 10 amps or so.
Pushing the start button without pushing the brake pedal does the same thing in an auto that pushing the button without pushing the clutch does in a stick. It turns on the ignition without running the starter motor.
I would say that in the absence of a real load tester, someone could put a meter directly on the battery and then run the starter motor with the gas pedal held down so that the engine would not start. This would truly give the system voltage while under load. It would really require two people to do this.Does this make sense?
Old Jun 16, 2013 | 01:02 PM
EVRose's Avatar
EVRose
My multimeter (Fluke 179) as a hold setting that will hold the highest or lowest reading. I just attach it to the battery and start the car. Thats probably as much load as the battery takes.
Old Jun 16, 2013 | 01:04 PM
cclive's Avatar
cclive
That's a great way to do it. Fluke is the best of the best...but probably costs more than a load tester. This provides more accuracy than having a second person watch the meter also!
Correction: definitely more than a load tester...
Old Jun 16, 2013 | 01:06 PM
eboggs_jkvl
Moderator emeritus
Bottom line, can the voltage be read from the dash if the FOB is not recognized? I think there should be a part of the instructions that says use a volt meter and check this, that, or the other or use a battery load testing piece of equipment like "????". To truly walk through the chart, there has to be a valid test on the battery and I want to keep it as simple as possible to give a "go" "no go" on the battery.
Old Jun 16, 2013 | 01:16 PM
cclive's Avatar
cclive
OK, I understand...I can't see any way to test the battery using the car, if the fob is not recognized. Without a working fob, the DIC will not ever say anything except "no fobs detected"...which of course is the car's way of saying "go away and leave me alone"!
Old Jun 16, 2013 | 01:18 PM
eboggs_jkvl
Moderator emeritus
Which then says the proof of a good/bad battery is something done when you get to that step and are still looking for a solution.
Either bring a load tester to the battery or take the battery to a load tester to prove good/bad on the battery.
ALSO, when the step calls to put the FOB in the slot, the ignition should then come alive and you can see the battery voltage, correct?
Old Jun 16, 2013 | 01:30 PM
cclive's Avatar
cclive
Yes, but that means the fob is recognized and also the DIC is not giving voltage under the load of the starter. In fact, even if the entire system is working fine, the DIC can never display the voltage when the battery is under the load of the starter motor.
Old Jun 16, 2013 | 01:59 PM
eboggs_jkvl
Moderator emeritus
True, but sticking the FOB in the slot is just the first step in the whole process. If the FOB is not recognized in the slot, the car battery needs checking eventually in the steps. Thus, we're back to getting the battery tested.
So, I conclude the instructions are as accurate as they can be and I don't need to edit the information.
Elmer
Old Jun 16, 2013 | 02:23 PM
cclive's Avatar
cclive
I agree...ultimately, the battery will need to be tested external to the rest of the system in order to continue in the diagnostic process.
Old Jun 16, 2013 | 11:52 PM
Pinky...'s Avatar
Pinky...
Hate to say it, but you need a good load tester or a shop that will do it for you.
Your battery needs to be fully charged before it is done for the most accurate readings. I'd recommend maybe seeing if your dealer can do it or find a good aftermarket shop that has a quality load tester. (Sun VAT40)
Old Jun 17, 2013 | 01:02 AM
EDinPA's Avatar
EDinPA
Buy a load tester. It is a good tool to have.
Old Jun 17, 2013 | 10:43 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
On our previous 2006 A6 and now 2009 A6, pushing the Start button without stepping on the brake just produces a DIC message something like "Depress Brake Pedal to Start, Dummy!"
To turn on the ignition without actually starting the engine in a A6, you push and hold the bottom of the switch for about 5 seconds, the car goes into Accessory and then goes into the "Ign On" mode.
Old Jun 17, 2013 | 11:33 PM
cclive's Avatar
cclive
Jim, I'm not sure that the DIC has that many characters... I didn't know that about the A6...thanks for the info and correction... On the M6, it does the same thing as the holding of the ACC position.
Old Jun 18, 2013 | 10:23 AM
eboggs_jkvl
Moderator emeritus
Fix yer DIC Chris! Mine comes on at start-up and reads:
One Big *** Mistake America! oooorrah!
Old Jun 18, 2013 | 11:30 AM
Gearhead Jim
St. Jude Donor '13
I had a special one made up, just to tell me all the things I do wrong in the car.
Old Jun 18, 2013 | 11:43 AM
eboggs_jkvl
Moderator emeritus
Dooooood! An iMAX dash!?
Elmer
Old Jun 18, 2013 | 12:08 PM
mickey5's Avatar
mickey5
Take the battery to Autozone or some such auto store. They test your battery for free. They also will read your OBD and give you a printout for free. Sure beats the stealerships.
Old Jun 18, 2013 | 09:33 PM
Pinky...'s Avatar
Pinky...
Yep! For a limited time only kids, you TOO can have some know nothing kid hook some half assed, poorly calibrated junk up to your car so you know what parts to throw at it! Come on down!
Do you have a dealership you regularly frequent, OP?
To Battery under load?
