2005 C6 Cruise control indicator off
Old 06-20-2013, 04:50 PM
Al1969
Al1969's Avatar
Default 2005 C6 Cruise control indicator off
Hello everyone,
Hope someone can help me. My cruise control indicator on the dash does not come on. The cruise control engages and works fine. I get the display on the DIC indicating speed. If someone had the same problem , can you give me an idea where to start? I thought about the fuse, but don't want to start fiddling with it, if it'll not solve the problem.
Thanks ,
Old 06-20-2013, 11:38 PM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
What "cruise control indicator on the dash" are you referring to? (Hint: There isn't one.)
Old 06-20-2013, 11:51 PM
EVRose
EVRose's Avatar
Yep, I've never seen one either.
Old 06-21-2013, 01:14 AM
paganharley
paganharley's Avatar
St. Jude Donor '11
There was one that showed on the dash and also in Hud. It looked like a small gear. Mine went also. I havent taken it in yet, figured it would cost more than what it is worth. Also mine was a 05.
Old 06-21-2013, 06:43 AM
FortMorganAl
FortMorganAl's Avatar
Location: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
2005 had an indicator? WOW, I learn something every day. It was eliminated in the 2006.
Old 06-21-2013, 09:42 AM
Larry/car
Larry/car's Avatar
My 2006 DIC just indicates CRUSE SET & speed
Old 06-21-2013, 09:56 AM
EVRose
EVRose's Avatar
I use it so seldom I've never noticed or cant remember. I'm checking it next time I go out.
Old 06-21-2013, 03:55 PM
Al1969
Al1969's Avatar
Yes there's one. The indicator would come on to identify you were in cruise control. You also see the wording on the DIC, but I do remember it on the instrument panel right above the fog lights indicator. Like you said, looks like a small gear. My cruise control works, but no indicator light. It also mentions it on the manual with a picture. I was wondering if others had the same problem and what corrects it.
Thanks,
Old 06-21-2013, 04:00 PM
Al1969
Al1969's Avatar
http://www.c6registry.com/technical/manuals/2005OM.pdf
Page 3-12
Old 06-21-2013, 04:10 PM
redrckt97
redrckt97's Avatar
Default you made me look
well - never noticed that on my 05 (had it 2 yrs) -- will definitely look for it on the way home from work today --- I use the cruise a lot.
Old 06-21-2013, 05:23 PM
EVRose
EVRose's Avatar
Originally Posted by Al1969
I believe you. I've only used it maybe 2 times a couple years ago and don't remember that being there.
Old 06-21-2013, 07:36 PM
mpuzach
mpuzach's Avatar
My '05 definitely does not have it. I don't even see the trace of the icon in the instrument cluster.
Old 06-21-2013, 08:22 PM
VET4LES
VET4LES's Avatar
Same here. I checked it this morning in the dark on the way to work. Cruise works and shows on the DIC but no gear.
Old 06-21-2013, 09:04 PM
EVRose
EVRose's Avatar
Just went for a drive and my 05 doesnt have it either. The manual is wrong.
Old 06-21-2013, 11:13 PM
Al1969
Al1969's Avatar
Then maybe I'm 'losing it'. I thought I had seen it on the instrument panel, but maybe I confused it with the one on my EXT. Perhaps the manual is wrong. Any other 05 owners that can clarify? It just bugs me cause I recall seeing it.
To 2005 C6 Cruise control indicator off
Quick Reply: 2005 C6 Cruise control indicator off
