Gps
Old Jun 20, 2013 | 10:23 PM
Chuckscorvette's Avatar
Chuckscorvette
Default Gps
I have a 2005 vert with the l2 package. Bose speakers. I asked the dealership if I found a factory nav system could they install it. When they ran the vin, they said it couldn't be done. Is that right?
Old Jun 20, 2013 | 10:36 PM
Bat Man's Avatar
Bat Man
uh, no. It can be done. Find a GPS from a 2005, search for the part numbers, and try to find one that matches.
Old Jun 20, 2013 | 10:48 PM
Fastoldguy's Avatar
Fastoldguy
OK... Have you "experienced" the C6 Nav system? Humm... well, it's Lacking to say the least.
Old Jun 20, 2013 | 10:56 PM
Chuckscorvette
Default Gps
Old Jun 20, 2013 | 11:09 PM
Bat Man's Avatar
Bat Man
Its honestly not bad at all.
Old Jun 20, 2013 | 11:13 PM
Fastoldguy's Avatar
Fastoldguy
Correct, compared to a Map.
Old Jun 20, 2013 | 11:25 PM
mpuzach's Avatar
mpuzach
"l2 package"? There's nothing even close to that. If you're referring to the 2005 "Preferred Equipment Packages", on convertibles they were 1SA and 1SB. (There was also a 1SX on coupes.) All 2005s with factory navigation (whether coupe or convertible) had the 1SB package; navigation was a stand-alone option that could be ordered only on cars also equipped with 1SB.
Old Jun 21, 2013 | 02:44 AM
HOXXOH's Avatar
HOXXOH
I'd prefer the paper map myself. At least it can be carried in the house or hotel room to plot the route or to make changes on the fly.
My road trips always include an atlas, individual state maps, a garmin GPS, a cell phone GPS, a notebook computer, and usually a wife who tells me where to go.
Old Jun 21, 2013 | 06:59 AM
C7Joy's Avatar
C7Joy
Garmin on the dash! Always gets me there!
Old Jun 21, 2013 | 07:35 AM
B-Vette's Avatar
B-Vette
I had a Kenwood/Garmin nav system installed - couldn't be happier!
Old Jun 21, 2013 | 08:09 AM
weathermaker's Avatar
weathermaker
And still, you get lost!
Old Jun 21, 2013 | 08:17 AM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
We have all kinds of aftermarket options for you that contain everything you will need to install and we can also prewire them for simple installation as well.
Here is a link to all the brands we offer for the C6
http://shop.doubledmods.com/C6-CORVE...KAGES_c600.htm
Myself I am a fan of Kenwood!
Call us if you need more help
Dennis
Old Jun 21, 2013 | 08:21 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I use my Garmin with ProClip on my 05.
Old Jun 21, 2013 | 08:22 AM
Chuckscorvette
Default Gps
I did mean 1sb package. I wonder why they said it could not be done?
Old Jun 21, 2013 | 08:28 AM
z51vett's Avatar
z51vett
Does she also tell you when to turn the turn signal off and honk the horn and ask how fast you are going and oh theirs a cop geeze you would think I've never driven before and I'm 7 years older than the expert. I have to explain myself If I make a sudden move as to why big whoops.
Oh sorry just venting about the shotgun rider.
z51vett
Doug
Old Jun 21, 2013 | 09:06 AM
Bat Man's Avatar
Bat Man
Because your car does not have the GPS antenna.
For the dealer to install the GPS antenna they would have to take the entire dash apart. That's how the service manual states replacement.
Luckily you do not really need to put the antenna in the factory position. You can put it near to the factory position and it will still work. Use Velcro and it won't budge.
Just install it your self, when you turn the vehicle on the nav screen will lock up with the theft deterrent.
All the GM dealer has to do is hook up the tech 2 and erase the vin in the nav unit and load yours. Done.
Old Jun 21, 2013 | 12:11 PM
iclick's Avatar
iclick
I just rigged a Zumo 665 to my the C6 LT1 recently using Garmin's motorcycle cradle dedicated to that model. It's been in use for some time on the Harley and I can now transfer the GPS with one button and no hassling with cables. There is no blocking of visibility and the angle of viewing is good. The result was excellent for my needs, shown below, and doing this also provided 12V car power as well as MP3 and Bluetooth phone support.
I fabricated a bracket from a sheet of 2mm-thick SS and mounted it with 3M Dual-Lock (similar to Velcro) in the .40" gap between the WS molding and removable top. See more details here. One caveat: This may not work well for those who need to remove the top and use the GPS, as the top is part of the securing mechanism. When I remove the top, which I don't do often, I will simply pull the GPS, too, as the cradle holds fine without the top and GPS mounted. A clip of some sort might rectify this limitation but I haven't gotten around to looking into that yet.
To Gps
Old Jun 21, 2013 | 12:14 PM
myfunz's Avatar
myfunz
Old Jun 21, 2013 | 12:27 PM
Bill Dearborn's Avatar
Bill Dearborn
No more lacking than any other Nav System. Carry a map and don't trust any of them and you will get along fine. Trust one of them and you could find yourself in a life threatening situation.
Bill
Old Jun 21, 2013 | 12:29 PM
billyboy47's Avatar
billyboy47
St. Jude Donor '17
