Haven't had my C6 long ... it's a replacement for my '03 that was destroyed when an SUV pulled out in front of me when I was going about 50 mph and 30 feet away ....
Never had a car with paddle shifters before, and was wondering what the best technique is for using them. And I mean basics ... do you keep your foot on the accelerator when shifting up, or remove it as you would when shifting a manual? And other tips would be appreciated too.
Honestly, I don't really see the utility of paddle shifters but just a lot cars have them now so there must be some use.
Their use is best when in S rather than D. Accelerating when using them is fine, that is totally up to you, but you of course don't have to. The trans will automatically rev match on downshifts as well. It you hold in towards the upshift for 3 seconds the trans will go out of the paddleshift mode and back to auto. Also you enter the paddle mode in S simply be using them.
Yes you can keep your foot into it. I normally start in 2nd and shift about 6k it takes a second to shift to next gear. With 1st it will hit rev limiter very fast. When you go into S mode standing still shift down to
1st then to 2nd if you want, that will put gear numbers in HUD & DIC
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
Another slick thing to do...
Forget the + on the Paddle...stick your fingers underneath the steerring wheel and in front of the downshift side of the paddle....
When up shifting, simply move the paddle lever forward...and downshifting, simply tap the lever back....no more fumbling for that silly, small "+" sign stuck in the corner of the wheel...
One of the best things about the paddler shifters is mountain driving. I almost never have to use the brakes regardless of how steep or twisty the roads are.
The difference between the paddle shift and letting the auto mode do the shifting, is you control when you want to go either up a gear or down a gear which means you can hold a gear longer then the auto will. Also you can simply put it in the Sport mode and it will shift automatically for you same as in the Auto mode, but if you are driving it in a more spirited mode the tranny will hold the shift point a little longer.
You can get the car tuned so the shifts are more precise also.
SOME cars with paddle shifters are made to use them.
They're more of a gimmick on the C6. Very slow to react. Just wind it out a few times and learn how many RPMs early you need to hit it to not bump the rev limiter. At 550rwhp I have to hit them around 1500 rpms early, wait for the delay, then hope to god it shifts in time not to bounce the limiter, lol.
They can be useful for holding gears on a road course on on winding roads, but they lack when comparing to many other cars. I'm happy the car has them rather than nothing because I have tracked it, but do wish they had been better implemented.
OP-
Congrats on your car, what year is it?
There are some significant differences in the various years of A6 production.
Originally Posted by RocketDawg
It's an '09.
We had a 2006 A6 and now the 2009 A6.
I like it a lot. Normally, drive around in S without using the paddles; but they are instantly available if I desire. Wonderful on a twisty back road.
There IS a lag between when you push/pull the lever, and when the shift occurs, and the engine is continuing to wind up during that time (unlike a stick shift). For the 1-2 shift, I hit the paddle about 5700 rpm. For 2-3, about 6100 rpm. Once you learn the technique for your particular car, the lag becomes a non-issue. If I can't think ahead of my car by two seconds, it's time to park and take a rest.
Totally agree. I didn't like that it had a bit of lag at first, but in thinking about it, there's no difference between knowing I have to hit the lever at 5700 RPMs versus 6200 RPMs to get a shift before redline. You have to hit the paddle at a specific time in either case.
The programming on my 2011 seems pretty spot on for downshifting under heavy braking. Especially the 3 -> 2 shift, the very slight amount of engine braking on engagement allows the car to rotate into the turn. It's really well balanced, IMO.
