Towing
Old Jun 29, 2013 | 10:39 PM
Chuckscorvette's Avatar
Chuckscorvette
Default Towing
I'm trying to prepare for possibilities. 2005 vert automatic. What should I be looking for to see if it is being towed properly or the person doesn't know what he is doing and I should call someone else? Thanks for all replays in advance.
Old Jun 29, 2013 | 10:57 PM
Bill Dearborn's Avatar
Bill Dearborn
The best way to have the car towed is on a roll back. However, the operator will have to have some boards to bridge the angle between the front of the car and the ramp. They put the boards in front of the front wheels and a few feet up the ramp. The boards change the approach angle so the front splitter doesn't hit the ramp. Don't worry about the air dam.
Another way of towing is to use a regular tow truck that has bars that extend under the car from the rear and clamp both rear wheels. Two bars to each wheel. The operator then lifts the rear wheels off the ground a few inches and tows the car slowly so the front doesn't bounce off the pavement. When my engine blew at the Glen two years ago that is how the car was towed off the track.
Bill
Old Jun 29, 2013 | 11:24 PM
ostbloom's Avatar
ostbloom
Just had mine towed two weeks ago after a guy hit me. First guy said he was going to pull off my bumper cover. I sent him down the road. Next guy was experienced, put the flat bed to the ground, put boards long ways out to from the ramp to the front of the wheels. Hooked a 8 foot chain on both front sides of the a-frames. Then hooked the wrecker cable to the center of the chain. Pulled it right up and it never touched the splitter! And I have a ZR1 splitter on a 12 GS. Without the boards it would have been a different story.
Old Jun 29, 2013 | 11:31 PM
michaelinmech's Avatar
michaelinmech
Bill
^ "Now Bill, when that little needle goes up into the red and reads *nine thousand RPM*, that's bad!
You done it deliberate... done it deliberate! Nine thousand, four hundred RPM... according to the little tell-tale button".
Old Jun 30, 2013 | 12:05 AM
jmoffett's Avatar
jmoffett
Old Jun 30, 2013 | 11:34 AM
Kenny94945's Avatar
Kenny94945
So where should the tow/drag chains attach?
Front and rear location examples please.
(On the A-arms doesn't seem so good to me, especially if the car won't roll freely.)
Old Jun 30, 2013 | 11:44 AM
Tally Ho's Avatar
Tally Ho
From: Out Where the Buses Don't Run, Eglin AFB/ Niceville FL
2022 Corvette of the Year Finalist -- Modified
2021 C6 of the Year Winner - Modified
2020 C6 of the Year Finalist - Modified
Bill
This is how my 427 was towed away after the deer strike. The splitter never touched the ground during the tow.
Old Jun 30, 2013 | 03:01 PM
andy82's Avatar
andy82
2017 C7 of Year Finalist
My advice: get a tow hook installed!
To Towing
