It seems like I read that the window timing can be reset ... but I had no luck with my searches. My dr side window doesn't go up all of the way when the door is closed and engine started. It will go full up with the window switch however. What am I doing wrong? TIA
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16,'19
After a power reconnect such as battery replacement, the
window index-up feature will not function until the system
is initialized. Once power is restored, do the following:
1. Close the door.
2. Raise the window by pulling up the switch.
3. Hold the up switch for three seconds after the
window is closed. Release the switch.
4. Hold the up switch again for three seconds and
release.
Remember to do both windows.
This is called resetting of the window indexing or power window initialize and is in the owner's manual. See page 2-17 of the 2005 owner’s manual, page 2-18 of the 2006 owner’s manual, page 87 of the 2007 owner’s manual, page 2-18 of the 2008 owner’s manual, page 2-18 of the 2009 owner's manual, page 3-18 of the 2010 owner's manual, page 2-18 of the 2011 owner's manual, or page 2-19 of the 2012 owner's manual.
Simple and in manual...if I recall close the door raise all the way up and then let go of switch, hold switch up for 2-3 seconds then repeat a second time and it should be set.
