Performance chips
Old Jul 9, 2013 | 01:05 PM
POCOTOO's Avatar
POCOTOO
Default Performance chips
I have read that "Performance Chips" are a waste of money in any vehicle. How can they make claims like these in the attached link?
http://www.gfchips.com/chevroletcorvette.aspx
THX
http://forums.corvetteforum.com/imag...ies/crazy2.gif
Old Jul 9, 2013 | 01:25 PM
dcarter0001's Avatar
dcarter0001
If you notice it's their customer's claims, not theirs.
Old Jul 9, 2013 | 01:32 PM
POCOTOO's Avatar
POCOTOO
It is the advertiser's ad. I do not particularly believe customer claims on an ad. Many times they are employees. I was searching for forum members that have actual experience.
If this ad is true, why wouldn't we all get an easy 20 to 60hp and increased mpg with this product?
Just askin'.
Old Jul 9, 2013 | 01:40 PM
Vette_DD's Avatar
Vette_DD
I'm sorry, is this the first instance of false advertising you've ever seen?
Old Jul 9, 2013 | 01:44 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
POCOTOO ...
How about you buy that "Performance Chip" and report back here the results?
Back to back dyno or 1/4 mile ET / MPH results would even be better.
Old Jul 9, 2013 | 01:51 PM
MikeMaj82's Avatar
MikeMaj82
I don't know about the Corvette, but I had a Superchips Cortex tuner for my G8, and I noticed a difference in acceleration and shifting, and all the other things I could do with it, like turn off AFM.
Old Jul 9, 2013 | 01:54 PM
POCOTOO's Avatar
POCOTOO
BACK OFF GUYS - IT WAS A SIMPLE QUESTION.
Can you explain to me why you would "attack" someone for asking a simple question?
Turbo6TA
"How about you buy that "Performance Chip" and report back here the results?"
Why would anyone do that if there were many that have already tried it and could relay the results......
JimTN
"I'm sorry, is this the first instance of false advertising you've ever seen? "
I'm sorry I do not find this reply humorous, especially from a "forum Moderator...
Is there anyone on here that has had real experience with these kits?
pocotoo
Old Jul 9, 2013 | 02:01 PM
Turbo6TA's Avatar
Turbo6TA
Originally Posted by pocotoo
Back off guys - it was a simple question. Can you explain to me why you would "attack" someone for asking a simple question?
___________________________
turbo6ta:
"how about you buy that "performance chip" and report back here the results?"
why would anyone do that if there were many that have already tried it and could relay the results......
Pocotoo
I certainly was not attacking you. I just suggested that you try it out and let us know.
And I say that because I don't think you will find one (1) person on this forum that has actually bought and installed this little 'chip' box.
Give it a try
Old Jul 9, 2013 | 02:03 PM
NormWild's Avatar
NormWild
Turbo6TA
JimTN
pocotoo
Performance "CHIPS", while OK for some applications like Diesel Trucks or Turbo Charged Imports are not ideal for our vehicles. These are typically generic "canned" tunes based on a standard change to certain ECU parameters such as AFR and Timing.
These are not optimized to your particular vehicle and any modifications you might have such as exhaust and cold air intakes, all of which will be different depending on many factors. You are always better off staying away from "chips" and spending the money on a quality custom Dyno Tune at a shop.
Old Jul 9, 2013 | 02:16 PM
POCOTOO's Avatar
POCOTOO
Thanks. I really appreciate the info. Obviously not for me. I will probably get a Dyno Tune in the future. I understand it voids the warranty, although I do not know why if it gives the vehicle optimum performance.
Thanks again Beatit
Old Jul 9, 2013 | 02:34 PM
Glenmcp's Avatar
Glenmcp
Someone who knows what they are doing can get some good results by tweaking the stock chip. I would start with that.
Old Jul 9, 2013 | 02:41 PM
Turbo6TA's Avatar
Turbo6TA
A good tune will not damage the engine, but GM has no control of who is doing the tuning, so they just void the powertrain warranty anytime they find out the tuning is altered.
If you think about it ... if the person doing the tuning was pretty much clueless as to what he is doing, he could set the timing to the point of causing engine failure, or set the rev limiter to a point that the engine may self destruct from over-reving.
A poor tune can certainly have catastrophic results if not done properly, and GM has no control who is messing with the PCM / ECM.
Old Jul 9, 2013 | 02:46 PM
POCOTOO's Avatar
POCOTOO
Thanks for your response.
Old Jul 9, 2013 | 03:04 PM
Ferocious C6's Avatar
Ferocious C6
Turbo6TA
JimTN
pocotoo
Translation: Hey guys, I'm butthurt because of the humor at the expense of me. However, despite having read numerous bad things about these "chips", I'm going to keep asking questions until I get the answer I want to hear.
Old Jul 9, 2013 | 03:15 PM
HOXXOH's Avatar
HOXXOH
Just askin'.
Because if it were true, we'd all have one and you wouldn't have to ask or search for forum members with actual experience.
Old Jul 9, 2013 | 03:22 PM
POCOTOO's Avatar
POCOTOO
WOW, REMARKS SO TYPICAL OF A TEENAGER - HOW OLD ARE YOU FEROCIOUS?
I'm hoping many others are seeing these childish, immature remarks.
I'm oughta this thread.......
Old Jul 9, 2013 | 03:29 PM
Tonylmiller's Avatar
Tonylmiller
THX
They can make any claims they want, I suppose. I'm not willing to risk my engine. If you do, please let us know the results.
Take this pill and lose 20 pounds! Only $19.99 for 10 of them! You see it all the time. Buyer beware.
To Performance chips
Old Jul 9, 2013 | 04:31 PM
MikeMaj82's Avatar
MikeMaj82
I've actually had experience with one of these kinds of "chips" in the past on my '99 cougar. Basically, it's just a resistor soldered to a couple of wires and put in a fancy box that you can mount in the engine bay. It connects to the IAT sensor in the airbox and is supposed to make the engine think you're sucking in cooler air.
So basically it's an overpriced fancy looking resistor that they charge $70 for. You can buy it for around $5.00 yourself in radio shack.
Old Jul 9, 2013 | 07:06 PM
vettman96's Avatar
vettman96
Can you even replace the chip? Wouldnt it just be a reflash of the existing firmware on the original chip?
Old Jul 9, 2013 | 07:16 PM
Dado5's Avatar
Dado5
Ebay has these same chips for $10
as explained above its just a resistor that tricks the engine to think it sucks colder air, they are all the same resistors. my friend sells these, he gets them bulk from china and sells for $10, $20 to $60 all depends how fancy the box is.
i have put one on my girls 2000 chevy silverado just to see, as i got it for free. she says she can see increase in mileage like 1 to 2 mpg and thats about it.
