C6 won't start sometimes... (loop?)
Old Jul 10, 2013 | 01:29 PM
greenbeauty's Avatar
greenbeauty
Default C6 won't start sometimes... (loop?)
My vette has a strange problem (sometimes)
When I'm trying to start the car sometimes the car won't start.
I press the brake or clutch, and press on start.
Then the "ping ping" sound is hearing, and then the display's are going off and on.
There is no message or something on the dashboard..
It's just in a loop.
When I try 60 seconds later the car is starting with no problems
What can be the couse of this?
I tried:
- Added a new fob (same problem)
I'm scared that there becomes a day that the vette won't start anymore
This is the movie I made of it:
or this link:
Old Jul 10, 2013 | 01:36 PM
crtaylor59's Avatar
crtaylor59
Have you checked the battery? There are several threads about funny things happening if the battery is not fully charged. I would start there especially if the battery is a couple years old.
Old Jul 10, 2013 | 01:40 PM
steveb601's Avatar
steveb601
Old Jul 10, 2013 | 01:46 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Battery connections also, including the attachment at the starter under the engine.
Old Jul 10, 2013 | 01:52 PM
greenbeauty
Hmm battery is replaced last year...
Old Jul 10, 2013 | 02:25 PM
BillH2121's Avatar
BillH2121
That's most likely a bad battery or battery cable issue.. I had two cracked batteries within a two year period - these cars are extremely sensitive to voltage irregularities. Each time, I had symptoms just like you but kept thinking it couldn't be the battery because it was fairly new. Check and replace your battery if needed and I bet the problem will be solved.
Old Jul 10, 2013 | 02:40 PM
blitzebill's Avatar
blitzebill
I get this too, but no "pings" just the "check engine light" comes on...then I try it again and it fires up.
battery shows 14.1 at start-up...14.5 when on the road.
Old Jul 10, 2013 | 03:39 PM
VET4LES's Avatar
VET4LES
Check the battery and connections. When your starting make sure the clutch is pushed hard on the floorboard.
Old Jul 10, 2013 | 05:26 PM
beaversstonehaven's Avatar
beaversstonehaven
[QUOTE=VET4LES;1584373691]Check the battery and connections. When your starting make sure the clutch is pushed hard on the floorboard. [/QUOT
Old Jul 10, 2013 | 09:06 PM
c6miller's Avatar
c6miller
if the battery is OK I'd check the ignition switch.
Old Jul 10, 2013 | 09:48 PM
Mad*Max's Avatar
Mad*Max
what year is your car and how long have you owned it? how long has the car been doing it? how often does it do it?
I have an 07 A6 which has been doing it since I bought it new 6.5 years ago -happens once in two months on average
Old Jul 11, 2013 | 06:21 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
If you want to private message me your VIN I would be happy to check for any open service related announcements. Keep me posted,
Kelly J.
Chevrolet Customer Care
Old Jul 11, 2013 | 10:06 PM
B-Vette's Avatar
B-Vette
I have something similar happening with my vehicle, I though it might be related to the ignition switch so I started a thread in this section as well.
Old Jul 11, 2013 | 11:00 PM
nykbob's Avatar
nykbob
Is your cell phone plugged into a charger? Try unplugging it and see if the car starts.
Sounds odd, but I had a problem getting my 09 to start, (although there was no beeping). Then I unplugged my cellphone from the charger and no problems starting.
Happened to be watching the Corvette instructional DVD and guess what, they said "Some cell phone chargers can prevent the car from starting". So as long as I plug my phone in AFTER I start my car, no issues.
Just a thought.
Old Jul 11, 2013 | 11:14 PM
Mad*Max's Avatar
Mad*Max
Old Jul 12, 2013 | 06:14 AM
Seadawg's Avatar
Seadawg
AND, make sure you have pushed it to the floor BEFORE you push the start button.
This was occassionally happening to me, and it had never happened, IF I am sure that I pushed the clutch petal first.
A good test is when it happens again, immediately release the clutch petal, and all of the light sequencing should stop. Then when you press the clutch the 2nd time, you should be able to immediately start your vette.
Old Jul 12, 2013 | 06:24 AM
greenbeauty
Some answers:
- The car is from 2006 (a6)
- I checked the connections of the battery, they are not green or something
- I do NOT use a cell phone charger
- I DO push the clutch in to the floor!!! hehe
Some new questions:
- Where is the starter located under the hood?
- Can the steering wheel column lock be the problem on my 2006 car?
(or is this only @ 2005 models
- How can I check is the battery is the problem?
The cell colour is green, normally this is good behaviour.
- The problem is most of the time when the engine is still warm.
With cold engine i've got no problems.
Thanks!!
Old Jul 12, 2013 | 07:42 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Crank relay? It is in the fuse block under the carpet on the passenger floor. An easy test is to exchange it with the backup light relay. See the owner's manual for the instrument panel fuse block page 420 in my manual.
To C6 won't start sometimes... (loop?)
