Dash Speaker
Old Jul 10, 2013 | 09:05 PM
vet55's Avatar
vet55
Default Dash Speaker
Anyone else hear a lot of lows in the Bose
system? What kind of speaker comes in
that spot? Maybe change it to a pure tweeter?
Old Jul 10, 2013 | 10:05 PM
Double D Mods's Avatar
0Double D Mods
Former Vendor
St. Jude Donor '12-'13
you need to change the 3.5 in the doors and the 5.25 in the rear if you want to get some more highs
I have these plug n play packages available we have been shipping daily to customers.
http://shop.doubledmods.com/C6-CORVE...AGES_c1397.htm
To answer your question....there is a 3.5 coax in the dash.
Dennis
Old Jul 10, 2013 | 10:10 PM
vig1116's Avatar
vig1116
a lot of guys replace the doors and the backs with better speakers like said above and unplug the dash speaker altogether for better separation...
Old Jul 10, 2013 | 10:13 PM
vet55's Avatar
vet55
Thx for the quick replies!
I will check out the packages.
Old Jul 12, 2013 | 10:08 AM
MTsVette's Avatar
MTsVette
From: O'Fallon Illinois - Currently own a 2016 Z06 1LZ A8 Coupe
I too unplugged the center dash speaker. The system sounds better to me...more separation left and right.
MT
Old Jul 12, 2013 | 10:59 AM
vet55's Avatar
vet55
MT
Thx for the response. I am insulating
the grille for a rattle this weekend.
I will unplug the speaker then.
I will report back...
Old Jul 12, 2013 | 11:09 AM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
Ditto what others here have said ...
1. Replace the OEM front (door) speakers with a set of 2-way component speakers
2. Replace the OEM rear speakers with a set of 2-way coaxial speakers
3. Add a single 8" or 10" subwoofer in the rear cargo area
4. Disconnect the center dash speaker
5. Power it all with a single 5-channel amp
_______________________________
It will look like this if you use your OEM head unit:
(The AOEM-GM24 in the photo below is just an adapter between your OEM head unit and the aftermarket 5-channel amp)
Old Jul 15, 2013 | 09:09 AM
vet55's Avatar
vet55
Thx!
Old Jul 21, 2013 | 03:30 PM
vet55's Avatar
vet55
Default Follow up:
Got the dash speaker grille off with a flat
blade screw driver. Pried up levering over
a screw driver handle covered with a
towel.
Glued speaker grille cloth in strips to
the contact surfaces of the grille. Used
3M 77 spray to glue it down. I insulated with
1/4 " foam sheet to the dash under the left side
and removed the dash speaker and used the same foam
to fill the speaker hole.
Used a Velcro strip to wrap the speaker
plug in for the speaker. Used a twistie
to bind the speaker wire. No further rattle.
Main thing is the stereo sounds fantastic
without the center speaker. A must do mod!
To Dash Speaker
