One time odd occurrence
Old Jul 12, 2013 | 12:11 AM
WhiteDevil828's Avatar
WhiteDevil828
2025 C8 of the Year Finalist - Modified
Default One time odd occurrence
Just curious if this ever happened to anyone else. I got in my 07' vert about a month ago and depressed the brake as normal and started the car, then I attempted to shift the auto into drive and I could not push the shift button to disengage the shifter. No matter how hard I tried I could not press the button and yes, my foot was on the brake. I turned the car off and opened the door and then restarted it but no luck. I turned the car off again and contemplated how I was going to get the car home since I was about 60 miles away. After about 5 minutes of quiet cursing I restarted the car again and I was able to put the shifter in drive like nothing was ever wrong. Another odd thing happened a few weeks before that. I open the door and after I got in realized my FOB was still in the house. The doors are set to auto lock. Gremlins?! Neither event has happened again since.
Old Jul 12, 2013 | 12:29 AM
okie08vette's Avatar
okie08vette
Check the battery first if it's low then all kind of things like this happen. Have the batter load tested replace if needed.
Old Jul 12, 2013 | 07:53 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
Until it happens again, don't worry about it. These cars are computer controlled and strange things happen occasionally that are never repeated.
http://forums.corvetteforum.com/c6-c...-this-car.html
Never happened again.
Old Jul 12, 2013 | 10:22 AM
z51vett's Avatar
z51vett
Solenoid on shifter going bad maybe the cost of new shifter is high. You can't just buy the solenoid.
z51vett
Doug
Old Jul 12, 2013 | 10:22 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I've had our 2009 fail to auto-lock a couple of times, never figured out why.
Ours is set to flash the lights when it locks, so I watch for the flash if I'm concerned about the neighborhood or contents of the car.
To One time odd occurrence
By Michael S. Palmer | 2026-06-03 11:00:24
