QUESTION - map light ?
Old Jul 13, 2013 | 02:15 PM
ZEE-OH-6's Avatar
ZEE-OH-6
Default QUESTION - map light ?
I own a C5 but my friend who is not a forum member owns a C6 and is dealing with an issue :
" When I get in my 2006 Vette and start the car the rear view mirror map lights come on and stay on until I turn the motor off. I tried per the manual pushing the bottom on the mirror for 3 and 6 seconds and all other times. It will not go off. This applies to both sides of the mirror map lights. "
Thank you in advance for your HELP - What's the solution?
Old Jul 13, 2013 | 02:18 PM
festone's Avatar
festone
The Map / Reading lights come on when the a door is opened. If they do not go out when door closes then it is possible that the door switch(s) are bad.
Old Jul 13, 2013 | 02:20 PM
hig4s's Avatar
hig4s
Map lights on the corvette are also considered dome lights and the button associated with the dash board lights also controls the dome light function.
Just push it to turn that function off.
Don't ask me how I know.
Old Jul 13, 2013 | 02:41 PM
Indy-V's Avatar
Indy-V
I had that happen to me once and had to push the dimmer switch to turn off the lights. I accidentally pushed it when I was cleaning the dash. Drove me nuts for a few days.
Old Jul 13, 2013 | 03:19 PM
Vette_DD's Avatar
Vette_DD
Many here have pushed the dimmer switch while cleaning the dash and didn't realize it. I did it about 3-4 months ago after having seen it posted here 8-10 times.
The owner's manual does tell you that turns on/off all the interior lights.
Old Jul 13, 2013 | 07:45 PM
ZEE-OH-6's Avatar
ZEE-OH-6
Thanks GENTS I will pass this on to him and see what happens ?
Old Jul 13, 2013 | 07:55 PM
z51vett's Avatar
z51vett
**** is on left side next to steering shaft right about knee high for tall folks.
z51vett
Old Jul 13, 2013 | 09:09 PM
ZEE-OH-6's Avatar
ZEE-OH-6
OK so I passed on what u guys posted and he emails be back " LOL, now one of my taillight blinker light is out. The one that blinks when making a right turn. I took it to a tire dealer one time and he replaced the bulb for free. However it was kinda ridiculous. They put the car on the hoist and about 3 or 4 men working under the car to replace the light, took about half an hour, omg. Tire dealer sold me some tires so he did it as a courtesy. "
Sorry for the bother but what do u guys think is going on ?
Old Jul 14, 2013 | 09:55 AM
Don-Vette's Avatar
Don-Vette
I think your friend needs to change the bulb and join the forum.
Old Jul 14, 2013 | 11:52 AM
ZEE-OH-6's Avatar
ZEE-OH-6
hehehe .... I AGREE ...
Old Jul 14, 2013 | 06:52 PM
APACHEDR1V3R's Avatar
APACHEDR1V3R
And not necessarily in that order either.
Old Jul 14, 2013 | 07:15 PM
N2TU's Avatar
N2TU
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'18
This forum rocks!...
Old Jul 14, 2013 | 07:22 PM
tomringo's Avatar
tomringo
From: Richmond VA Everyone should have a VetteGuard
Default Interior Lights
This helps a lot, I couldn't get them off when exiting. Pushed the button, and they're off however...when I exit the car the lights stay on for about 10 mins, if I leave the window down I can reach in push the button an they go off, but is there a way to reduce the wait time if all closed up??
Old Jul 15, 2013 | 04:13 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Normally, the lights stay on briefly after you open and close the door; like when entering or exiting the car. There may be a sensor that keeps them from coming on in bright light like outdoors, but I haven't tried to look that one up.
There is a 10 minute timer on the lights, unless you open or close the door again. If the lights are staying on for 10 minutes, that really means they are trying to stay on forever but the timer is shutting them down. "All" you need to do is figure out what's going on with the switches, trying to keep them on.
Describing this stuff in print is a lot harder than actually doing it on the car.
Good luck with yours.
To QUESTION - map light ?
