Door Chime
Old Jul 15, 2013 | 12:33 PM
retaf87's Avatar
retaf87
Default Door Chime
When I open the driver's door ('13 coupe) after car sits for a couple of days, the "chime" rings until car is started. Any ideas or suggestions? Thanks
Old Jul 15, 2013 | 01:07 PM
Vette_DD's Avatar
Vette_DD
You stayed too close to the door with the fob for too long after you got out and closed the door the last time you got out.
Old Jul 15, 2013 | 01:35 PM
Bigredwing's Avatar
Bigredwing
Say what?
Old Jul 15, 2013 | 01:37 PM
EVRose's Avatar
EVRose
Originally Posted by Bigredwing
Say what?
Jim is right. If you do that the car thinks the fob is left inside and is warning you with the chime.
Old Jul 15, 2013 | 01:44 PM
charlie598's Avatar
charlie598
yesterday I left my fob in the cup holder, went in the house,came out and the car locked itself.Waited 15-20 minutes and it UNLOCKED itself. FOB stuff is getting OLD.
Old Jul 15, 2013 | 01:54 PM
Don-Vette's Avatar
Don-Vette
I'm confused. Lol
All I know is the fob stays in my right front pocket at all times and I never hear any chimes.
Old Jul 15, 2013 | 01:58 PM
charlie598's Avatar
charlie598
yeah, I was too..........................
Old Jul 15, 2013 | 01:59 PM
charlie598's Avatar
charlie598
service writers reply was" Never heard of that before, they will never do that!!"
Typical
Old Jul 15, 2013 | 04:14 PM
retaf87's Avatar
retaf87
Thanks Jim. I will try moving away from door quicker!
Old Jul 15, 2013 | 09:44 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
I move away from the door quickly when exiting, but still get the chime if I:
let the car lock itself, wait a few minutes, and then unlock/open the door and close it again, then return later and unlock/open.
Or something like that...
"it's not a bug, it's a feature!"
Old Jul 15, 2013 | 11:28 PM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
Use the DIC Vehicle Personalization feature and turn on "Fob Reminder".
The car will beep 3 times after you exit to tell you it thinks the fob is still inside.
If you ignore this or don't have the feature turned on, the next time you open the door it will start beeping again.
Use the DIC to turn off "Passive Door Locking" if you want to prevent the car from locking itself.
This is all covered very thoroughly, along with many other 'quirks' in the Owners Manual.
Old Jul 15, 2013 | 11:50 PM
Knob Jockey
Typical
Service writer was right. The car does not operate that way.
It will not under any circumstance, miraculously un-lock itself.
If you were "locked out" and the door switch didn't work, maybe the switch is dirty/intermittent.
If the car is locked, and the only fob nearby is inside the car, the car won't open.
Try this test, roll down the window, get out and lock the car, then after it's locked reach in and put you fob in the cup holder.
Now try to open a door. Just like 'normal' cars, you can lock your keys inside. Good reason to turn on Fob Reminder.
To Door Chime
