It will run best with 91(or higher) octane. Lower octane won't hurt it, but performance will be somewhat diminished since the computer will retard the timing to prevent knock. A Z06, however, requires at least 91 octane.
I think the owner's manual explains it pretty clearly.
The ECM has a high octane and low octane timing table that it references. If you get enough knock the car will switch to the low octane table to protect the engine.
It's best to use 91 or 93 depending on what's available for best performance and to keep the ECM from constantly having to pull timing to protect. However, the car WILL adjust to 85 or 87 but you'll probably see timing being pulled even at less than WOT. Also you'll be relying solely on the knock sensors to protect your pistons from getting holes burned in them.
That is mostly sea level to probably 4,500ft advice. At higher elevations you can get away with lower octane due to the density altitude and oxygen levels or something. Its why you'll find 85 octane in places like Colorado.
Also, you will get less mpg with regular and so the cost savings is less than it seems.
Top Tier brands, regardless of octane, keep your engine cleaner inside, some people don't seem to care but I do.
So I use Top Tier premium. Most of the majors are top tier, but not all. Google is your friend!
Sounds stupid probably, but besides what ever GM first put in, my car has only ever seen Chevron 91. Daily driver too. I didn't even let the dealer fill the tank when I bought it because I didn't want some lot boy rowing gears and putting budget station 87 in.
I don't push my 2012 Coupe (6A) very hard, so when I go on a long distance ride I use 87 octane and get 28/29 mpg consistently. At the same time saving at least 30 cents a gallon.
Bob
congrats @ saving $4.50 in your 70K sports car LOL
