Can anyone here explain just how the American Car Craft belt tension pulley cover is installed. I ordered one along with a few other items from the Forum Store (WCC) but there were no instruction with it.
It appears to be a simple install when you first look at it, but once you try and fit it in, that is another story.
I first removed the FRC on the right hand side and there is also an attachment that bolts to the head that has some electrical line as well as I believe vacuum or fuel lines. I unbolted that and moved it out of the way, but I still could not get it to fit.
