Quick question for the Vette Experts
Old Jul 24, 2013 | 09:53 AM
sav426's Avatar
sav426
Default Quick question for the Vette Experts
What is the ground clearance difference between an 05 Z51 and the 13 Grandsport.
Where I park and cover the Vette during winter I want make sure I can still get this one there, and dont want to find out by scraping under my doors.
Looked up online specs but doesnt say anything about ground clearance. Its backed into the spot onto a slab and covered than once every few weeks i start and drive it forward a bit so doesnt sit same spot.
I hope this question makes sense.
Old Jul 24, 2013 | 10:04 AM
MikeyTX's Avatar
MikeyTX
Veteran: Marine Corps
St. Jude 15 Year Donor
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Heh ........ the older car will sit lower due to normal wear and tear on the suspension. So if it clears, the newer one will.
Old Jul 24, 2013 | 10:09 AM
JoesC5's Avatar
JoesC5
GM says the GS/Z06/ZR1 has .4" less ground clearance than the base C6.
Old Jul 24, 2013 | 10:16 AM
sav426's Avatar
sav426
Im researching storage units as my garage is full of bikes and lawnmowers etc
Old Jul 24, 2013 | 10:34 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
True, but wouldn't his older C6 have settled more over time from use ?
Old Jul 24, 2013 | 10:37 AM
sav426's Avatar
sav426
Yep you mentioned that. I sure hope so I bet the GS wont even have 2k miles come Oct time. It gets put away in Oct.
Last edited by sav426; Jul 24, 2013 at 10:38 AM. Reason: Didint realize Mikey WAS the first poster :)
Old Jul 24, 2013 | 11:23 AM
Bill Dearborn's Avatar
Bill Dearborn
Tape measure will be your best friend. Measure from the ground to the point you are afraid of rubbing and then see what things may cause an issue on the slab where you will be parking.
Bill
Old Jul 24, 2013 | 11:38 AM
MikeyTX's Avatar
MikeyTX
NCM Lifetime Member
Bill
Apple makes tape measures ?
To Quick question for the Vette Experts
