Paint code location?
Old Jul 27, 2013 | 09:39 PM
lordofwar's Avatar
lordofwar
Default Paint code location?
where is the paint code location on a 2012 gs?
thanks for any help.
Old Jul 27, 2013 | 09:44 PM
RicK T's Avatar
RicK T
Glove box sticker. Likely the next to last (bottom) line.
Here's a pic of one, you can see the "57U" code in the middle of the next to bottom line:
http://forums.corvetteforum.com/1580262481-post8.html
Old Jul 27, 2013 | 10:01 PM
Vette_DD's Avatar
Vette_DD
Codes are in alphabetical order and codes that begin with a number are listed last.
Old Jul 27, 2013 | 10:31 PM
lordofwar's Avatar
lordofwar
I found the sticker.problem is there are a lot of numbers.how do you know which 1 is the paint code?my car is carbon flash metallic.
Old Jul 27, 2013 | 10:37 PM
psp6158's Avatar
psp6158
For Carbon Flash your number is 58...
Old Jul 27, 2013 | 10:52 PM
lordofwar's Avatar
lordofwar
got it thanks.
Old Jul 28, 2013 | 01:07 PM
Snake.Oiler's Avatar
Snake.Oiler
St. Jude Donor '13 thru '20,'22,'24 thru '26
The 57U is the RPO for the exterior color. The actual paint code a body shop would use is the 637R found on the BC/CC (base coat/clear coat) line.
Take your pick.
Old Oct 4, 2021 | 11:32 AM
Racermutt's Avatar
Racermutt
1st Gear
Default Paint code locations by year
CORVETTE YEAR STICKER PLACEMENT 1984, 1985 White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car. 1986, 1987, 1988, 1989, 1990, 1991, 1992, 1993, 1994 White sticker located on the underside of the center console lid. 1995, 1996 White sticker located on the underside of the rear, right storage compartment cover (on the passenger side) of the car. 1997, Early 1998 White sticker located on the underside of the rear, left storage compartment cover (on the driver side) of the car. Late 1998, 1999, 2000, 2001, 2002, 2003, 2004, 2005, 2006, 2007, 2008, 2009, 2010, 2011, 2012, 2013 White or silver sticker which is located inside the glove box compartment on the glove box door. 2014, 2015, 2016, 2017 Silver sticker which is located under the rear compartment carpet, near the battery. 2018, 2019, 2020, 2021 GM completely revamped the RPO Code sticker. They moved the silver sticker to the driver-side door and added a QR Code. The RPO Codes can only be read using a QR Code scanner.
Old Oct 5, 2021 | 10:19 PM
jbc1995fb's Avatar
jbc1995fb
Great 1st post in a thread thats 8 years old. Lol.
welcome to the forum.
To Paint code location?
