wheel barrels
Old Jul 28, 2013 | 03:13 PM
corvettejack's Avatar
corvettejack
Default wheel barrels
Has anyone changed the gray color of their wheel barrels some say you can remove the gray to expose chrome or aluminum I tried this wasn,t happy with the look almost like a brushed aluminum look I have CRM was thinking of trying that along with brake calipers any input? Thanks Jack
Old Jul 28, 2013 | 04:12 PM
ZR1 136's Avatar
ZR1 136
I havent done it but heard some plasti dip the barrels. Try a search to see if anything pictures show up.
Old Jul 28, 2013 | 04:21 PM
VET4LES's Avatar
VET4LES
I painted mine.
Old Jul 28, 2013 | 05:17 PM
C6Whatever's Avatar
C6Whatever
E
Old Jul 28, 2013 | 06:03 PM
zrone90's Avatar
zrone90
I painted mine black. I like the look against the chrome. Not to hard to keep clean.
Old Jul 28, 2013 | 06:45 PM
haljensen's Avatar
haljensen
If the wheel is Chrome the inside barrel is Chrome.
The difference in the apparent finish is that the outside face of the wheel is smoothed and polished before Chroming , the barrel isn't.
Old Jul 28, 2013 | 07:02 PM
Jim2003's Avatar
Jim2003
My 13 wheels are chrome aluminum according to the order form. I thought under the gray paint was unpolished aluminum. My 03 jad polished aluminum wheels. I actually liked those wheels better than my 13's wheels.
Why oh why did GM deccide to paint the barrels gray instead of polishing them? Dumb decision by my way of thinking.
Old Jul 28, 2013 | 07:26 PM
haljensen's Avatar
haljensen
All OEM Corvette wheels are aluminum. All OEM chrome wheels are full chrome, front & back, inside & outside. The only difference in the front & back is that the fronts are prepped for show Chrome.
Old Jul 28, 2013 | 09:04 PM
gunnerjuju's Avatar
gunnerjuju
I plastdipped mine black. Love it
Old Jul 28, 2013 | 09:57 PM
AmmoVet's Avatar
AmmoVet
Exactly. I removed the paint on mine and found that they are a little rough but look ok. Some have reported finding blemish's and I know I found at least one on the set of 4 I have. Nothing you would see when it is installed and on the car.
Old Jul 28, 2013 | 10:01 PM
Top_Fuel's Avatar
Top_Fuel
When you strip the barrel paint off of chrome wheels, it is hit or miss on what you are going to find. Sometimes the chrome looks really good...other times there are serious imperfections in the chrome. Bad chrome in the barrel doesn't prevent a wheel from making it out of the factory...as it will be painted over anyway. Check out this thread...
DIY Paint Removal from Chrome Gumby Wheels
I did that mod on my car, but I would not recommend it if you daily drive your car and you don't want to maintain your barrels with a good wax. A couple of years of exposure (and no maintenance) can have the barrel chrome peeling. That's why GM painted them in the first place.
Old Jul 28, 2013 | 10:03 PM
LPT2011's Avatar
LPT2011
painted mine black this year ... '07 silver metallic with chrome and drilled rotors ... and now the black looks like better than OEM. Also did the "glass coat" on the chrome and barrels and maintenance has never been easier
I am extremely happy with the change
Old Jul 28, 2013 | 10:05 PM
Top_Fuel's Avatar
Top_Fuel
After removing the paint on my chrome Gumbies, I discovered a spot inside one of the rear wheel barrels where the chrome plating was flawed. It appears that a buffer wheel "burned" through the chrome plating...exposing a spot of bare aluminum. You can see the spot when the wheel is off the car. With the wheel on the car, you can't tell it’s there unless you really look for it.
Here are a couple of pictures of the spot so you can see what I'm talking about. Look directly behind the hole where the valve stem should be...
Old Jul 28, 2013 | 10:26 PM
Jim2003's Avatar
Jim2003
Good info guys. I just have to decide if I want to strip the gray paint. I do lve the shinny barrel look for sure!
Old Jul 28, 2013 | 10:43 PM
RoadReady's Avatar
RoadReady
Originally Posted by VET4LES
I painted mine.
Do you have to dry and use detailer on the entire barrels after each wash?
Old Jul 28, 2013 | 11:05 PM
v1 rot8's Avatar
v1 rot8
Hanging around to see what everyone has to say
Old Jul 28, 2013 | 11:12 PM
VET4LES's Avatar
VET4LES
You can't tell the matt black from the road grim and brake dust. I use a long brush with car wash soap but it always looks good.
To wheel barrels
Old Jul 28, 2013 | 11:32 PM
Batmbl's Avatar
Batmbl
Old Jul 29, 2013 | 12:46 AM
c6vette142dude's Avatar
c6vette142dude
Painted mines black with a nice gloss. Easier to clean and looks great against the satin finish of the wheels.
Old Jul 29, 2013 | 08:39 AM
jakesblades's Avatar
jakesblades
going black this week.........jake
By Michael S. Palmer | 2026-06-03 09:39:05
