Service Fuel System
Old Aug 2, 2013 | 02:27 PM
TJEvans224's Avatar
TJEvans224
Default Service Fuel System
I am getting a Service Fuel System message, and my fuel gauge goes to empty. The Threads on this forum are from 2005. Has anyone found a cure other then drop the tank and replace the sender? Thanks Tom
Old Aug 2, 2013 | 02:52 PM
crusher1's Avatar
crusher1
Try a bottle of Techron Fuel System Cleaner first. See if that clears it up. Worked for quite a few people.
Old Aug 2, 2013 | 03:00 PM
TJEvans224's Avatar
TJEvans224
I have added Techron Fuel System Cleaner, and good gas, so far, still not good.
Old Aug 2, 2013 | 03:06 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Prepare to drop yer tank.
Elmer
Old Aug 2, 2013 | 03:40 PM
VET4LES's Avatar
VET4LES
There is a flash for this issue on the 05. It was a common problem when they were new. My tank was lowered and the sending unit replaced. Shortly after that GM released a flash that took care of the problem. Check it out with your dealer.
Old Aug 9, 2013 | 09:52 AM
TJEvans224's Avatar
TJEvans224
So the latest is, at 225 miles which is less then half so that would be the left tank, the gauge went to empty and the service fuel system went on. I got home unhooked the battery terminal for 10 minutes hooked it back up and all was fine. ?? Is there any fix other then replacing the left sender? Thanks Tom
Old Aug 9, 2013 | 11:19 AM
Gray Weasel's Avatar
Gray Weasel
Default service fuel system
Just went thru this mess ...The in tank sending unit is they have to drop the tank to get to it I had them replace both I have 80,000 miles on the car and it is not much more to replace both labor is the killer hope you are under warrnity it is pricey
Good Luck
Old Aug 9, 2013 | 12:15 PM
TJEvans224's Avatar
TJEvans224
I have 75,000 miles on it, no warranty, how much did it cost? did you go to a Chevy dealer? Thanks Tom
Old Dec 1, 2013 | 11:03 PM
Crush2's Avatar
Crush2
Default cost of replace?
Good Luck
What was the bill for the replacement? Did you get both L/R done? Is there a thread about the flash? Mine is a 2006, 64k miles. Yesterday the gauge was at about 9/16, then dropped to 7/16, then started CLIMBING, all the way to 3/4, in the span of about 10 miles. Pulled off and topped of tank, showing FULL and appropriate range on DIC. Appreciate any facts or even anecdotes about similar problems.
To Service Fuel System
