Check active handling...
Old Aug 9, 2013 | 10:02 AM
ChrisCamp's Avatar
ChrisCamp
Default Check active handling...
So I get in my 09 M6 yesterday after work and as I am leaving the lot my parking brake light comes on a dings at me...I look over and see that the brake is down. Also it is saying service active handling, traction etc...
I put the clutch in and shut the car off and re-start it and it clears up.
This AM we are heading out and it does it again...so I shut it off and re-start and it clears up....
Battery?
Old Aug 9, 2013 | 12:34 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Possible. Original battery? Connections can also go bad, including down at the starter (under the car).
Old Aug 9, 2013 | 12:51 PM
ChrisCamp's Avatar
ChrisCamp
It is the original battery...I will check all connections and probably get her a new battery just because I love her so much!
Old Aug 9, 2013 | 10:18 PM
K9KUZ's Avatar
K9KUZ
There's lots of electrical connections.....and don't forget the ground connectors also.
Old Aug 9, 2013 | 11:59 PM
Keith Tedford's Avatar
Keith Tedford
Also check the positive battery cable connection at the starter for proper torque. Kopr Kote is good for making good connections and stopping corrosion at the same time. http://www.jetlube.com/KOPR-KOTE-Industrial-P748.aspx If buying a new battery, make sure that its Reserve Capacity is 120 or better if available. If the voltage drops below 10.5 volts while starting, the computer gets fuzzy brained and doesn't think straight. (Lay man talk).
Old Apr 27, 2015 | 06:07 PM
rob20rx7's Avatar
rob20rx7
Having this same issue with my 09 z06. Start the car and service active handling comes on including little light. I can cycle through the options traction control off then traction control on and light goes away. Competitive driving mode no longer an option. What can this be? Dealer is lost says they can't figure it out. I did have the battery off for a while when doing my supercharger install. The issue started when I started the car for the first time afterwards.
Old Apr 27, 2015 | 11:46 PM
rob20rx7's Avatar
rob20rx7
Im going to try disconecting the battery and reconnecting it tomorrow. nothing else seems to make sence
Old Apr 28, 2015 | 12:38 AM
AmmoVet's Avatar
AmmoVet
Search this subject. At one time this was related to loose connections on the connectors under the drivers seat. Some fixed the problem by adding zip ties to the connectors.
Old Apr 28, 2015 | 12:15 PM
cclive's Avatar
cclive
It could be one of the two big blue connectors that are in the fuse box under the passenger footwell carpet. I would suggest checking them out and perhaps re-seating them. They can cause all kinds of crazy things to happen electrically.
Old Apr 28, 2015 | 12:33 PM
grandsport6's Avatar
grandsport6
Check for a recall pertaining to the positive assurance lock retaining clip at the base of the steering column. When the column is tilted the connector can momentarily open causing the light to go on.
To Check active handling...
