With regular street tires, you will probably break loose long before you break anything. Put drag slicks on the car, dump the clutch at 5k rpm on a prepared track and you will eventually find the weak parts in the drivetrain. From what I have read, the rearend or half shafts in our '05 C6 would be the first thing to give up the ghost. Automatics are much more forgiving than stick shift setups as they absorb the shock better.
You can run FI whether turbo or SC, but you'll be limited as to how much boost you can run. On a stock block, perhaps 5-8 lbs. If you run meth or race gas a bit more. If you do it the right way and go with a forged bottom end, then you can run much more boost.
I recall dating a woman with a forged bottom end one time - only she called it 'Buns of Steel' . . . . .
