Now what...
Old Aug 16, 2013 | 12:25 AM
garye's Avatar
garye
St. Jude Donor '12-'13-'14-'15, '21
Default Now what...
I just bought my first set of tires for my 11 GS that are not run flats. What is the best combo for tire repair, Fix a flat or slime and what compressor would work best. I know, I know I've got AAA and I can call them, but just in case I can't reach them, whats a good combo?
Old Aug 16, 2013 | 02:38 AM
Knob Jockey's Avatar
Knob Jockey
St. Jude Donor '11-'12-'13-'14-'15
I bought a 'Slime Kit' that includes a small compressor with clips for a direct connection to the battery.
It also has a light and a selection of plugs and and some tools.
And I have AAA too.
Old Aug 16, 2013 | 04:42 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
And I have AAA too.
I have AAA too, but no repair kit ... only a compressor.
Where can you get the Slime Kit? And is "Slime" a brand and basically just a can of Fix-a-Flat? Can you get them at WalMart, Target, etc., or do you have to go to a car parts store?
Old Aug 16, 2013 | 04:47 AM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
I don't know if it's the absolute best or not, but I have a Viair 90P that has long cables and clips to the battery. It works well and seems to be built well. Cost was just under $80. I haven't really used it, but tested it out by topping off my tires, and it was pretty fast and seems to be built well.
Old Aug 16, 2013 | 08:22 AM
The Director's Avatar
The Director
The top 4 most important things to have are:
- Cell phone
- AAA or other roadside assistance
- Green Slime
- Air compressor
By the way, my local Chevy dealer said that in at least 50% of the cases they have seen, Slime did not destroy tire pressure sensors. You can get Slime at Walmart.
Old Aug 16, 2013 | 09:04 AM
o_town_racer's Avatar
o_town_racer
Compressor, a plug kit, and roadside assistance. If you ever do use the slime, be prepared to purchase a new tire pressure sensor.
Old Aug 16, 2013 | 09:32 AM
Globeman's Avatar
Globeman
If you have a repair kit, don't forget a pair of pliers to pull out whatever punctured the tire and a good flash light.
Old Aug 16, 2013 | 09:37 AM
Top_Fuel's Avatar
Top_Fuel
There are some suggestions in THIS thread.
Check your PMs...
Old Aug 16, 2013 | 07:48 PM
etaylor14's Avatar
etaylor14
I have the Viair90 also and a tire plug kit and AAA!!!
Old Aug 16, 2013 | 07:49 PM
ATC399's Avatar
ATC399
runflats
Old Aug 16, 2013 | 07:52 PM
truckplay's Avatar
truckplay
compressor and plug kit for me (no run flats) never fixaflat.
Old Aug 16, 2013 | 08:14 PM
michaelinmech's Avatar
michaelinmech
It astounds me the stuff people will stuff into their Vette (pliers, flashlight, slime, tire plugs, air compressor, inflation adapters, alligator clips, gloves, tarp, etc) all to risk dangerously laying along side the road on a dark rainy night . . . in lieu of run-flats.
I'll certainly admit that the first generation run-flats were fraught with compromise. But today's generation are performance comparable with their non-run-flat sisters in almost every aspect.
Oh well - be careful out there guys . . . roadside tire repair isn't without risk.
Old Aug 16, 2013 | 08:57 PM
Silverado Desperado's Avatar
Silverado Desperado
Slime states their product does not hurt tire pressure sensors. They offer a kit that has a substantial air pump that airs up a full size tire in 3 minutes. Most little portable compressors state 15 minutes. The kit is part number Slime 70004 that sells for $100 to $129 but can be had for $49 including shipping (do a search that includes Walmart, Amazon, eBay, etc). It also has tire plugs, tire plug tool, inflator adapters for other things as well. The compressor can plug in the lighter and also has aligator clips for direct connection to the vehicle battery for full power.
Nice kit, nice product.
Hope that helps!
Old Aug 16, 2013 | 09:01 PM
MikeERWNC's Avatar
MikeERWNC
Slime - Fix a Flat
PLEASE! Don't put that **** in your tires...
As someone who does a lot of motorcycle tire changes for people.
That stuff is just nasty.
When you break the bead that crap oozes out on to the tire machine and on the floor.
The inner wheel is all green and slimy. It is just a green chunky gooey mess.
I know you aren't the guy who will be changing the tire. But do think about the guy who has to.
Get the rope plugs from Wal-Mart and a small compressor or a can of CO2.
If you need more than that, get a tow.
Old Aug 16, 2013 | 09:04 PM
michaelinmech
Originally Posted by MikeERWNC
Slime - Fix a Flat
^ And if you need a tow, you're gonna need a Roll Back . . . . .
Old Aug 16, 2013 | 09:20 PM
Knob Jockey
I would have continued to buy run-flats if there were any rears consistently available in 345/30-19's.
There's only one I've found, Michelin PS-ZP (OEM Viper) and they are almost always out of stock/back-ordered at Tire Rack.
Slime kit appeared to be a viable option and it is claimed to not adversely effect the TPMS.
Believe me, I'm no fan of laying on the side of the road to plug/fix a tire.
Old Aug 16, 2013 | 09:30 PM
MikeERWNC's Avatar
MikeERWNC
Then consider tipping the guy who has to replace your tire.... Just saying.
To Now what...
Old Aug 16, 2013 | 09:43 PM
michaelinmech
Why not use OEM sizes with more availability ?
Old Aug 16, 2013 | 09:45 PM
Silverado Desperado
http://www.walmart.com/ip/Slime-Flat...ype=10&veh=aff
Old Aug 17, 2013 | 03:36 AM
Knob Jockey
Good advice.
If I had to 'slime' my tire, I would absolutely tip the tech that had to repair it and deal with the additional mess.
I always schedule tire changes when my shop can have one of their best techs available. They have never damaged my wheels or my car, and I always tip them even for a 'normal' service.
Because I prefer these these wider wheels.
