window - door issues
Old Aug 18, 2013 | 11:39 PM
panhead50's Avatar
panhead50
5th Gear
Default window - door issues
closed passenger door and window kept going up to seal then unseal. hit the window control and it stopped but will not move up to seal position. tried indexing the window but no luck. then tried passenger door and it would not pop open. drivers door works fine. whats up?
Old Aug 18, 2013 | 11:44 PM
raspyc6's Avatar
raspyc6
^answer may well be "window regulator" dysfunction. I have this on mine. You might notice slack in the window and lazy window indexing upon opening and closing of the door.
Old Aug 18, 2013 | 11:46 PM
panhead50's Avatar
panhead50
5th Gear
will that affect the door as well?
Old Aug 19, 2013 | 03:06 AM
Gering's Avatar
Gering
Tolero Apto Victum
Sir,
This sounds like a door pad issue. I had to replace both of mine a few months ago. They are very cheap and easy to replace.
Old Aug 19, 2013 | 11:55 PM
panhead50's Avatar
panhead50
5th Gear
Thanks for your input guys. I will check it out and let you know.
To window - door issues
