Poor throttle response
This came up on some of the replies so here is what I can offer:
The car is an automatic with paddle shift. The experience of the lag is when driving in normal driving mode (not paddle) and I go to hit the gas to accelerate hard. The lag is something that seems to be noticeable. I am not talking about a stall effect but rather a short hesitation (half second to a second(, then downshift and away I go. If I am just accelerating under normal driving conditions it is not an issue, just under hard acceleration and only until the downshift occurs. For example, i may be running 40 mph and choose to go faster by mashing the gas. In that instance, the car falls on its face, then perks up and launches. Hope this helps describe what I am experiencing. By some of the replies this seems to be a known issue and I will research a little in the archives too. Thanks.
Last edited by Westy39; Aug 19, 2013 at 05:22 PM. Reason: Update to provide more information
Do research on Chuck CoW (Corvettes of Westchester), and CoW Booster, and cow tune....
_______________________________
As you can see by the graph below, a mechanical throttle control using a cable system gives a linear throttle response .. When the throttle pedal is pressed 1/4 th of the way to the floor, the actual throttle blade in the throttle body will be open 25%. Press the throttle pedal down 3/4th of it’s available travel, and the throttle blade will be open 75%.
However, do to the programming of the “Drive by Wire” throttle system in the LS3, LS7 and LS9 Corvette engines, the throttle is not at all linear. Especially just off idle and in the first 65% of it’s range.
In fact, looking at the chart below, you can see that when the throttle pedal is pushed down 30% of it’s total travel, the actual throttle blade will only be open 10%. At 50% pedal travel, the throttle blade is open 35% of it’s total range. This is what gives poor throttle response during normal driving.
The CoW Booster does an amazing job of restoring the throttle response in the area of the lower throttle angles by operating the throttle system in a linear fashion as would a mechanical cable operated throttle.
In fact, ...when the throttle pedal is pushed down 30% of it’s total travel, the actual throttle blade will only be open 10%. At 50% pedal travel, the throttle blade is open 35% of it’s total range. This is what gives poor throttle response during normal driving.
If you hit the pedal in neutral do you still have a lag in throttle response?
Check this forum vendor: http://www.fasterproms.net. Jeremy can help you out.
