Changing diff fluid
Old Aug 22, 2013 | 07:19 AM
GOLD72's Avatar
GOLD72
Originally Posted by LMB-C6
That's old information - GM issued a TSB with a new part number: Dextron LS Gear Oil 75W-90, part #88862624
There is no need to add friction modifier with the new stuff.
OP - It's a pretty easy process. The fact that GM went though several iterations of recommending different fluids before finally settling on this one tells me there was an issue there - why not run with the latest?
This member did a write up: LINK
See my Post #5. DEXRON LS GM part #88862624 is the correct fluid for any C6 vette for Diff fluid changes. Introducing the old stuff may cause chattering that many have complained about for years.
Old Aug 22, 2013 | 10:44 AM
choprfgr's Avatar
choprfgr
Not to bust anyone's bubble but I am willing to bet any diff lube after
3K miles is gonna be dark - that criteria isn't a criteria.
Old Aug 22, 2013 | 11:00 AM
LS WON's Avatar
LS WON
Originally Posted by 01VETTECOP
I did mine myself. I used Amsoil and their additive. If it isn't making noise don't mess with it. If you do it and want some pointers let me know.
Same here in my 2005. No problems with rear end. At 33,000 miles had factory fluid changed over to Amsoil Severe gear rear diff. fluid.
Old Aug 22, 2013 | 12:48 PM
GOLD72's Avatar
GOLD72
AMSOIL Severe Gear 75W90 used in three different vettes with excellent results. My first AMSOIL purchase was for Severe Gear to stop a severe chattering of my 06Z and this was prior to the introduction of DEX LS fluid as factory fill for MY2009.
Old Aug 22, 2013 | 02:27 PM
HOXXOH's Avatar
HOXXOH
Of course, if the mfg put black dye in the original lube, they wouldn't sell as much, due to the fear factor being eliminated.
Way too many people get overly protective of their "special" low mileage car, but then treat their DD like crap and it never has problems.
Old Aug 22, 2013 | 02:38 PM
MikeERWNC's Avatar
MikeERWNC
The oil in mine went in looking like honey...
The black stuff which came out after 10K miles is not anything I would want circulating for 100K miles in my car.
My Corvette is my driver, 24K since January.
Old Aug 22, 2013 | 05:01 PM
HOXXOH's Avatar
HOXXOH
With another 14K since the change, don't you think it's due again?
Old Aug 22, 2013 | 05:07 PM
MikeERWNC's Avatar
MikeERWNC
I just did it about 2K ago when it started clicking again.
If I have to change it every 10 -15K to keep it quiet, I am good with that.
I have never had a car that didn't feel better after some fresh fluids.
Just my routine.
I am just happy my cars hold up with minimum trouble for the amount of miles I put on them.
With that said, the Corvette has been the worst car to date.
All of the other cars function properly without the massive amounts of repairs like I have had to do to the Corvette to keep it on the road.
Old Aug 22, 2013 | 05:33 PM
Red08's Avatar
Red08
I did some looking around in the owners manual. I have a couple of questions...
1) I have a 2008 base coupe. Do all corvettes have limited slip differentials? If not, how do I find out if mine does?
2) Once the diff is completely drained and empty, how much is needed to fill?
Thanks guys!
Old Aug 22, 2013 | 07:12 PM
MikeERWNC's Avatar
MikeERWNC
I buy two quarts and use this to install.
When it starts coming out, stop and cap it off. Just under two.
Old Aug 22, 2013 | 09:19 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Originally Posted by ELP_JC
Mine was like that too, with only 3K miles. A lot of crap in there from assembly. MUCH better to change it early IMO. After that, you can leave it for much longer.
We had our 2009 changed at ~8k miles, using the GM 75-90. Then changed again at ~50k miles and sent a sample to Blackstone Labs. They said both the fluid and the diff itself were in excellent shape, and recommended going significantly longer before the next change.
Old Aug 22, 2013 | 09:44 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
Originally Posted by GOLD72
Mileage?? Low miles and no chattering would suggest leaving it alone. If you do change it, the new DEXRON LS (GM #88862624) fluid will definitely be an upgrade to the factory fill in your 2008. DEX LS became factory fill in MY2009 to resolve chattering problems.
Is it true we don't need to add the friction modifier when using this new Dextron LS ?
Old Aug 22, 2013 | 09:53 PM
  #33
need-for-speed
CI 1-4-5-8-9-10 Vet
Thanks guys!
Yes, they all have limited slip diff
Old Aug 22, 2013 | 09:56 PM
  #34
need-for-speed
CI 1-4-5-8-9-10 Vet
Does that fit the GM LS lube bottle ?
Can you tell us where you bought it ?
Old Aug 22, 2013 | 10:13 PM
  #35
AZCE's Avatar
AZCE
You can buy a pump just like this at pretty much any auto store or even Sears.
Old Aug 22, 2013 | 10:17 PM
  #36
LMB-C6's Avatar
LMB-C6
True, you do NOT need to add anything.
I think that will fit but I bought the other kind of pump, because it was more versatile. The problem I ran into was the GM LS lube was so thick it would collapse the suction side hose. I replaced it with some heavier walled vinyl hose and it was smooth sailing.
Old Aug 22, 2013 | 10:35 PM
  #37
AimHigh's Avatar
AimHigh
Originally Posted by AZCE
I would recommend OEM fluid for the diff, I've heard good things about Redline but have never tried it myself.
Don't mess with it as stated previously, otherwise I use Redline and have had great results. Eliminated my rear chatter/noise.
If you ever do the tranny try the Redline as well, shifts like butter.
To Changing diff fluid
Old Aug 23, 2013 | 12:01 AM
  #38
LS WON's Avatar
LS WON
On my other car 15 years ago I used Redline MTL on 5 spd. manual trans. It shifted much better even after switching to factory new ATF then back to Redline for comparison purposes. I was going to sell the car back then because of this until I put in the Redline MTL fluid.
About a year ago I had clutched replaced and gears were not smooth shifting. Put in new Redline synthetic Trans fluid and now it is smooth as ever. It saved me from selling the car again which is 25 years old now.
Old Aug 23, 2013 | 06:52 AM
  #39
MikeERWNC's Avatar
MikeERWNC
Yep. It fits all Quart and Gallon oil bottles.
They are 7.00 shipped from Ebay.
Buy two.
When I did my AT I snapped off the top of one hitting the bottom of the car.
I look at them as cheap and disposable.
When they get dirty and nasty, I just throw them away and open a new one rather than waste time cleaning them.
Old Aug 23, 2013 | 07:00 AM
  #40
MikeERWNC's Avatar
MikeERWNC
That doesn't explain why the car started chattering...
The oil might still have life left in it, but if your car is chattering maybe you should replace the oil. As in my case.
I personally would rather replace the oil for 40.00 when the car gets noisy so I can drive a quiet car instead of paying 40.00 to get my oil tested and still be driving a noisy car because some lab tech said the oil was still fine.
If I had a car that was not making noise, I would still replace the oil at regular intervals just to help keep the differential somewhat clean and avoid any unneeded wear because I was too cheap to replace my fluids before they are 100% worn out.
But you keep paying the laboratory, they really like your money.
