Tires
Old Aug 21, 2013 | 12:09 AM
wingbone's Avatar
wingbone
Default Tires
Does anyone know where to purchase raised white or yellow letters on tires for the corvette.
Old Aug 21, 2013 | 01:29 AM
bolivar's Avatar
bolivar
Did we just go back to the future for about 20 years?
Old Aug 21, 2013 | 01:57 AM
AYello1's Avatar
AYello1
dye pencils are available, in many colors. Use them to make your own "white letters". If it looks as corny as I think it will, at least you'll be able to wash the dye off with a little lacquer thinner. If it looks as good as you are imagining, try calling Coker Tire and see what they can come up with.
Old Aug 21, 2013 | 04:19 AM
Torchsport's Avatar
Torchsport
St. Jude Donor '15 thru '26
Here ya go.
Old Aug 21, 2013 | 07:33 AM
Seadawg's Avatar
Seadawg
They would have to be pretty small letters, if you stay with the stock rims and low profile tires.
Old Aug 21, 2013 | 07:37 AM
FortMorganAl's Avatar
FortMorganAl
From: Currently somewhere in IL,IN,KY,TN,MO,AR,MS,AL, or FL
No tire maker makes a lettered tire in a size that would fit. Just finding ANY non-factory size tire combination that doesn't cause issues with the active handling and traction control is difficult and requires careful selection.
To Tires
