Keyless remote replacement?
Old Aug 22, 2013 | 06:31 PM
RJS91RGTP's Avatar
RJS91RGTP
Default Keyless remote replacement?
Question for anyone with experience. I have a working #1 remote, only one that came with my car, a 2007 coupe. The case of this remote is broken and beat up. I want another one and my question is do I need to buy a #2 or can I buy another #1 and just program it? Seems like there are a lot of number 1s for sale on eBay, new and used at pretty good prices, Any input or guidance would be appreciated.
Thanks!!
RJ
Old Aug 22, 2013 | 06:35 PM
RicK T's Avatar
RicK T
Number on the case doesn't matter. It's for you to keep them straight, not for the car.
The actual functional number of a FOB is determined by the order in which it's programmed to the car.
spdkilz911's Avatar
spdkilz911
You can buy another number 1 and program it. I only received one also (#1). It was in good shape so I bought a #2 and had it programmed for a spare. When I bought the extra fob they asked if I wanted the #1 or #2.
Old Aug 22, 2013 | 07:58 PM
psp6158's Avatar
psp6158
Keep in mind that if the previous owner had the 2nd fob and had it programmed, you will be doing the number 3 which is great for a spare, but it will not keep the memory of your seat, mirror etc...
Old Aug 22, 2013 | 08:01 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
You could buy a number 1 and swap the guts and not have to program anything.
Old Aug 22, 2013 | 08:40 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
orrrrrrrr you can have the #1 & #2 FOBs in hand and do the long program and code them yourself and totally eliminate the "Original #2" Fob from working on your car.
That's what I would do. If you add a new FOB, it will be #3 and not retain the memory functions associated with FOBs 1 & 2.
Get the FOBs, numbered 1 & 2, do the long procedure and insert the FOB with the number 1 on it first as you program. It'll be #1 and the second FOB you program will be #2. That other missing FOB is now relegated useless.
>>C6 Fob Programming and Glove Box Slot Testing Procedures<<
Elmer
To Keyless remote replacement?
