IMO if the car is raced, anything other than drag racing, it might be a good reason to change all four. OTOH if drag raced or used on the street I see no reason to toss two good front tires, even if they are stock GYs.
Just curious, how many miles on the car? Your situation is kind of reversed, usually the fronts go bad and the rears still have plenty of tread on them...
Id do all 4 and enjoy the added performance and security knowing they all match and sell the 2 good ones.
I replaced my OEM tires last spring, and debated replacing only the fronts since the rears still had "decent" tread on them. I decided to just go ahead and replace all four with Firehawk rft's. I am glad I did...they are a matching set all around, and are quiet and handle great. Leaving the OEM GY's on the rear would not have helped the noisy tire issue.
I replaced the fronts on my car with Pilot Super Sports and still have the original Goodyears on the back. It seems to be just fine, although mixing standard and run flat tires is not recommended.
I bought my car a year ago and it's an '09. Actually, one of the rears has been replaced since its manufacture date is in 2012.
Your tires are about 7 years old. You really shouldn't be using tires that old. Might want to replace all four of them.
don't mean to hijack the thread. either the previous owner replaced the tires before trading or the dealership put new ones on. Firestone Firehawks is what is on the vette now. good/bad?
My 06 came with FS WO RFs from the dealer where it was traded in. I like them very much. Good traction and quiet. I have nearly 10,000 on them and I can't tell they've ever been driven. Niiiice!
I wouldn't put an all season tire on their with summer tires. You'll have a loose front end in the wet and loose rear in the dry. I don't like mixing tires because although you might not use the full performance of the car in normal driving you may during emergency driving.
Besides the fronts are the cheaper tire on the C6. A bargain compared to the rears.
you need the max stopping and handling ability of all four of your tires in an emergency. not one axle going one way, and the other....
Geebus man, the difference, if any, wouldn't be anywhere near a catastrophe...'one axle going one way...' They're all radial tires with superior sidewall flex keeping the rubber on the ground especially at severe lean angles. Only a profound difference in tread design or tread thickness would create some kind of ill handling anomalie on a same size tire. And even then the handling difference if any, would be hard to discern on the rear, the fronts would transmit a lot more information.
I did a little net research on this for a actual scientific report on the different friction coefficients on new and used tread because I dont like the "well I paid $60,000 for my car, so I think you should shell out the maximum amount of money on every purchase too" standard fair. Unfortunately, I couldn't find anything conclusive that had any kind of math or a study to back it up.
From most accounts, iclick is correct. More so if you are a fair weather driver on street conditions where over-steer and under-steer (performance driving) on dry roads are not going to come into play. In a braking situation, the used tires on a dry road will have a greater friction coefficient, causing better stopping power. Would it cause any noticeable difference in control? The much larger brakes put a greater force on the front wheels to begin with, so a tire that has more tread hitting the pavement, may actually increase performance?
