Two 427's
Old Aug 25, 2013 | 12:30 PM
mpuzach's Avatar
mpuzach
Originally Posted by billiam01
I think the L88 is getting mixed up with the ZL1 motor which was all aluminum.
Yup, exactly.
Old Aug 25, 2013 | 12:52 PM
KABAL182's Avatar
KABAL182
I stand corrected. mpuzach is correct about the 67 L88 engine. If you were one of the 20 that ordered one, it also mandated extra cost options such as the J56 heavy duty break option, and G81 limited slip. When I was typing did get ZL1 on the brain , sorry guys.
VETJAZZ's Avatar
VETJAZZ
Very
Old Aug 25, 2013 | 12:54 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
How nice is that, perfect picture!
Old Aug 25, 2013 | 01:01 PM
Frank's C6's Avatar
Frank's C6
Originally Posted by Big Dan 427
I went to a local event last night and was parked next to a 1967 427 with what the owner says is a L89. I believe only 20 cars ever got the
L89 from the factory but according to the owner GM built 200 more and the motor could be bought which was the case with this car. Some of you experts out there may know, all I know was that the car was gorgeous. He is the third owner and claimed it had racing history.
Here is my 427 with his 427.
Thanks for sharing.I love the 427.
Old Aug 25, 2013 | 02:15 PM
mpuzach's Avatar
mpuzach
Interestingly, in '67 only it also mandated RPO C48 (heater / defroster delete). In all three years ('67 through '69) it also mandated F41 (special front and rear suspension), J50 (power brakes), and K66 (transistor ignition). In '67 and '68 it came only with M22 (heavy duty 4-speed manual transmission) but in '69 you could also opt for M40 (Turbo Hydramatic). Ah, the good old days when there were so many power train choices!
Old Aug 25, 2013 | 02:17 PM
mpuzach's Avatar
mpuzach
Same here. I can honestly say that if I owned a 2013 427 convertible I wouldn't even consider buying a 2014 Stingray. Since my C6 is a "lowly" 2005 coupe, however...
Old Aug 28, 2013 | 06:22 AM
Frank's C6's Avatar
Frank's C6
Hi mpuzach,
but is still a great Vette.I have the same year and is fun to drive everyday.
Old Aug 28, 2013 | 09:22 AM
z51vett's Avatar
z51vett
Not quite. L89 and L88 were both iron blocks with aluminum heads. L89 was essentially the L71 solid lifter tripower 427 but with aluminum heads instead of iron. Its primary benefit vs. L71 was weight savings. L88 was a totally different ball game. Also an iron block with aluminum heads, it had a single 850 CFH Holley 4-bbl carburetor.
Thank you for the corrected info I worked on one of the L89's for a customer every weekend because it continued to run after shut down. I wanted to pull heads and clean combustion cambers but boss at City Chevrolet said no. So I played with timing and idle adjustment. That was the fall of 1966 telling my age now.
z51vett
Old Aug 28, 2013 | 10:28 AM
GrandSportRob's Avatar
GrandSportRob
Luv to see the classic & modern 427 together...
Old Aug 28, 2013 | 03:33 PM
deadsexyii's Avatar
deadsexyii
Awesome pics!
Old Aug 28, 2013 | 03:49 PM
sam90lx's Avatar
sam90lx
Great Vette's Dan!
Old Aug 28, 2013 | 04:26 PM
  #33
USA1 427's Avatar
USA1 427
Here's my 427 (on the right) next to my buddy's, next to my other buddy's ZR1 !! Now there's some beauty!!
Old Aug 29, 2013 | 05:57 AM
  #34
Frank's C6's Avatar
Frank's C6
Great pic and awesome Vettes.
Old Aug 29, 2013 | 07:01 AM
  #35
jack5hd's Avatar
jack5hd
m22 tranny.a.ka. "rock crusher"
