HUD erratic
Old Sep 6, 2013 | 09:19 PM
xxvetteman's Avatar
xxvetteman
Default HUD erratic
Anyone have this happen or know what to do about it? I will drive my 06 one day and the HUD is working fine and the next time I drive it the HUD will not come on. None of the controls will do anything to make it work. Like it is dead one time and fine the next time. Thanks
Old Sep 6, 2013 | 09:25 PM
AimHigh's Avatar
AimHigh
First thing members are going to ask you is what shape the battery is in and is it charged correctly....then go from there.
Old Sep 6, 2013 | 09:44 PM
xxvetteman's Avatar
xxvetteman
Bought the car spring of 08. Original battery would not hold a charge probably from sitting on dealer lot for too long. Got a free warranty replacement OEM battery June 08. Seems to be charging OK.
Old Sep 6, 2013 | 11:03 PM
Norskie's Avatar
Norskie
When mine went erratic it was a bad battery.
Old Sep 6, 2013 | 11:34 PM
AimHigh's Avatar
AimHigh
That's a long ride on a battery.....might ought to get it checked. Vettes are super sensitive to crappy batteries,
Old Sep 7, 2013 | 12:46 PM
Andrew6@TheDoubleAA's Avatar
0Andrew6@TheDoubleAA
Former Vendor
Houston Events Coordinator
St. Jude Donor '11-'12, '14
I believe in the Beer Fairy
I had a customer come to me with a factory HUD issue similar to yours, after pulling everything apart we came to realize the the HUD was barely plugged in which caused the issues. Might want to check connections.
Old Sep 11, 2013 | 09:24 PM
xxvetteman's Avatar
xxvetteman
Tried a known good 6 month old battery and still no HUD. So where are these connections located?
Old Sep 11, 2013 | 11:17 PM
Former Vendor
behind the DIC cluster. Pop off the surround piece where the hud switch and fuel gauge etc... is and remove this with connections etc... The Cluster is held by "4" 7MM screws. Remove those and pull the cluster out. There are 2 connections on the back side verify those are pushed in all the way. Verify the Projector in the back is plugged in all the way and verify the switch to HUD is plugged in. If you still have issues give me a call and lets see what we can do about walking through some other scenarios.
Andrew
(832) 457 9253
Old Sep 11, 2013 | 11:33 PM
michaelinmech's Avatar
michaelinmech
Andrew
(832) 457 9253
^ Very nice of Andrew !!!! How great to read about one Menber helping another
Old Sep 12, 2013 | 04:40 PM
ButWhatDoIKnow's Avatar
ButWhatDoIKnow
Are you familiar with the up and down settings in the controls?
Sometimes it is working, but out of your view. Check the manual.
Old Sep 15, 2013 | 09:34 PM
xxvetteman's Avatar
xxvetteman
Thanks Andrew, I will try this!!!
Old Sep 16, 2013 | 12:40 PM
Former Vendor
sounds good, If you have any issues feel free to give me a call.
Old Sep 16, 2013 | 04:13 PM
Chevy Cust Svc's Avatar
Chevy Cust Svc
If there is anything I can do please let me know! Andrew can provide more technical advice than I can. If you want to send me your VIN and mileage I can look for open service announcements. Keep us all posted,
Kelly J.
Chevrolet Customer Care
Old Sep 17, 2013 | 09:40 PM
xxvetteman's Avatar
xxvetteman
I didn't want to start taking things apart on the dash so I thought I'd try the easy stuff first. I charged the battery overnight and when I started the car this morning the HUD was working. It looks like this battery and the one I thought was good were not fully charged. Thanks to all who offered help! Vette guys are the best!!!
Old Sep 18, 2013 | 07:07 AM
Former Vendor
Good deal for an easy fix
Old Sep 18, 2013 | 07:23 AM
Hope it was just the battery that was the problem. That's an easy fix.
To HUD erratic
