lowering a c6
Old Sep 10, 2013 | 07:26 AM
mooty1's Avatar
mooty1
Default lowering a c6
Can you lower the front of a c6 on stock bolts the same way as on a c5
Old Sep 10, 2013 | 07:55 AM
truckplay's Avatar
truckplay
sort off. it is easier on a 6. take the pressure of the spring with a bottle jack and turn the adjusting bolt, you may need to let it soak in pb blast, wd40 overnight. then drive around until the spring settles, it could take 50-100 miles.
Old Sep 10, 2013 | 08:53 AM
08 ATOMIC-Z's Avatar
08 ATOMIC-Z
If you do this you need to have your allignment redone. If not you will screw up your tires very fast.
Old Sep 10, 2013 | 09:50 AM
mooty1's Avatar
mooty1
Everybody says this and they are probally right but I did my 02 z06 and it did not hurt the tires
Old Sep 10, 2013 | 11:25 AM
Homer3D's Avatar
Homer3D
The change in height is so slight that it might not cause the tires to wear excessively, but it is still a good idea to do the alignment.
I lowered my 2005 C6 on the stock bolts and I think I got maybe half an inch drop.
Old Sep 10, 2013 | 02:42 PM
fairlydangerous1's Avatar
fairlydangerous1
Down side to this ?
Old Sep 10, 2013 | 03:04 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Originally Posted by fairlydangerous1
Down side to this ?
You scrape an ant's a$$ and most every other thing that is 2mm above street level.
Elmer
Old Sep 10, 2013 | 03:15 PM
Luster's Avatar
Luster
Down side to this ?
If you have a splitter, you'll need to start a separate savings account to buy a new one about once a month.....
(Lowered on stock bolts....)
Old Sep 10, 2013 | 03:17 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
I have an '07 that I lowered with the stock bolts all the way. I did not cut the bushing. I have had it like this now for over 6 months and I have not had it aligned and I see no wear on the tires. As for scraping, I don't seem to have much of and issue except with the stock front air dam, but it scraped before it was lowered. Not as much, but it did scrap, mostly when going in and out of my driveway and leaving parking lots if not on an angle.
Old Sep 10, 2013 | 05:38 PM
Homer3D's Avatar
Homer3D
This is why I haven't lowered my 2013 GS. I have already have the front splitter replaced once at stock height.
Old Sep 15, 2013 | 08:24 PM
pkincy's Avatar
pkincy
Lowering a C6 on stock bolts will dial in about 1/4 inch toe out from current settings and about another degree of negative camber.
If the excess camber doesn't get you the toe out certainly will.
And I have not noticed the splitter being that much more of a problem. I am lowered all the way on stock bolts but do have 285/345 tires which gives me back about 1/2 of that lowering with extra tire diameter.
My C4 is a real problem with coilovers but I do keep a couple of extra splitters in the garage for it.
Perry
Old Oct 10, 2013 | 07:20 AM
danny_acs's Avatar
danny_acs
Cruising
On a separate note, how would you deal with the underskirt of the standard C6? It already rubs speed bumps quite a lot at standard height as it goes quite a lot lower than the floor... so if you drop the car by an inch, would it be wise to "trim" it a bit?
Old Oct 10, 2013 | 07:37 AM
LFZ's Avatar
LFZ
Let it scrape...it takes abuse pretty well, because it's made to do so. Mine is less than an inch from the ground and hits everything. Still holding up.
Old Oct 10, 2013 | 08:14 AM
danny_acs's Avatar
danny_acs
Cruising
nice ha ha. How much did you drop yours?
Old Oct 10, 2013 | 09:09 AM
LFZ's Avatar
LFZ
a lot
Old Oct 10, 2013 | 09:50 AM
franman69's Avatar
franman69
it looks like 'a lot'... (looks nice)
Old Oct 10, 2013 | 09:57 AM
1Sikstik's Avatar
1Sikstik
Elmer
and you can forget about speed bumps
raised mine back up a bit, screw that rubbing everything bs
To lowering a c6
Old Oct 10, 2013 | 09:58 AM
Jers06C6's Avatar
Jers06C6
If you lower wait a good 100 miles or so before you have an alignment. Let the car settle and dial in the height you are looking for. 100 miles wont kill your tires.
Old Oct 10, 2013 | 10:10 AM
danny_acs's Avatar
danny_acs
Cruising
good tip, i was going to do alignment only after a short ride..
Old Oct 10, 2013 | 11:51 AM
pkincy's Avatar
pkincy
I have asked the forum vendors of the front air dam for both my C4 and my C6 if it would be possible for them to offer a part that is 1 inch less deep than stock. Their answer was no.
One did recommend that it likely could be cut with a band saw. The parts for my C4 are $50 and for the C6 are $90, so buying a set and having them cut would not be too expensive.
You would lose that little 90 degree lip that does give the part a lot of stability however which is why having them manufactured a bit shorter is the best move.
For an entrepreneur that is a business opportunity.
