Squeak/Squawk in telescopic column
Old Sep 23, 2013 | 05:00 PM
myvette2015's Avatar
myvette2015
Default Squeak/Squawk in telescopic column
Hi,
I own 2006.5 Corvette and vehicle has the tilt/telescopic column (RPON37)
Recently the column developed a squeak or squawk noise when temperature outside is less than 70 degrees.
This noise is only when the telescopic column extends to full up position.
The Corvette has 14,000 miles and has been flawless less this noise in the column.
Has anyone else experienced this problem. If yes what was the fix?
Thank You
Old Sep 23, 2013 | 09:16 PM
Bill Dearborn's Avatar
Bill Dearborn
You might try using some silicon to lubricate the rubber seal at the bottom of the steering column where it the column goes through the dash.
Bill
Old Sep 24, 2013 | 11:30 AM
myvette2015
Hi Bill,
Will try this procedure.
Thanks for the reply.
Old Feb 12, 2019 | 03:03 PM
myvette2015
This works, but not lasting effect.
To Squeak/Squawk in telescopic column
By Michael S. Palmer | 2026-06-03 11:00:24
