keep npp closed all the time?
Old Sep 27, 2013 | 02:00 AM
Stavesacre21's Avatar
Stavesacre21
Of the dozens of threads I've read about the NPP exhaust, this is the first one that ive read that actually wants to keep the exhaust flaps closed. Not sure why you would want to once you get high off in the revs. As others have said, if you were to do that you would be creating backflow into the exhaust and thus losing horsepower.
Just leave them how they are now, as they're not doing any damage or causing any problems.
Old Sep 27, 2013 | 06:22 AM
Hameister's Avatar
Hameister
2015 C6 of the Year Finalist
Originally Posted by JohnsC5
I pulled the fuse the moment I picked up my GS and haven't put it back. To each his own, but I don't find it too loud under any condition. My previous car, a MBZ C63 with the resonator deleted was much louder and even that wasn't offensive. I guess it depends what you're used to.
You've seen some magnificent views John.
Thanks for sharing those beautiful photos, I enjoyed them.
They show you have a good eye for composition.
Old Sep 27, 2013 | 07:56 AM
mack99's Avatar
mack99
My mufflers have the "z06 muffler mod" done so they are straight pipes and alot louder than your stock pipes
Old Sep 27, 2013 | 09:33 AM
deadsexyii's Avatar
deadsexyii
Originally Posted by mack99
My mufflers have the "z06 muffler mod" done so they are straight pipes and are as loud as your stock pipes with the flaps open
Fixed it for ya.
Old Sep 28, 2013 | 06:21 PM
mack99's Avatar
mack99
So Im probly gonna look for another set of Stock Z06 mufflers to put on instead of my modded set.
In the meantime, how much HP you think is lost when I have the flaps closed?
Also, are the stock mufflers going to be alot quieter?
Old Sep 28, 2013 | 06:34 PM
haljensen's Avatar
haljensen
HP loss is minimal. GM only advertizes 6 HP for the NPP over the very restrictive stock exhaust.
Stock Z06 are marginally quieter than modified ZO6 but much louder than stock C6 exhaust.
Old Sep 28, 2013 | 06:41 PM
mack99's Avatar
mack99
In the diagrams I have looked at for the muffler mod is looks like the perforations in that main pipe are what allow the exhaust to route to the other pipe?
When you do the mod and you close up those perforations, how is the exhaust getting to that other pipe?
Old Sep 28, 2013 | 06:52 PM
z51vett's Avatar
z51vett
Get an after market controller and you will have the best of both worlds remote open and close Sunset orange creations and one more but the name escapes me at the moment. The controller mounts in the left cubby hole drill small hole to run vacuum lines. run wires to front under carpet and your done less expensive than mufflers.
z51vett
Doug
