Ceramic brake pads
Old Sep 27, 2013 | 05:12 PM
stasny_05's Avatar
stasny_05
Default Ceramic brake pads
If one was to purchase used brake calipers with fairly new ceramic pads from someone else would you have to change pads anyway, rebed the pads on your car, or shouldn't have to worry and they will work!
Old Sep 27, 2013 | 06:17 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
different rotors, yours? I'd say, yes. you'll have to re-bed to your rotors.
Old Sep 27, 2013 | 06:19 PM
phileaglesfan's Avatar
phileaglesfan
Old Sep 27, 2013 | 06:36 PM
TJay74's Avatar
TJay74
SAnd the pads flat and then rebed them.
Old Sep 27, 2013 | 08:00 PM
stasny_05's Avatar
stasny_05
Thanks for the response!
Old Sep 27, 2013 | 08:10 PM
RocketDawg's Avatar
RocketDawg
CI 6-7-8 Veteran
St. Jude Donor '09
When you say "bed" the pads ... do you mean the practice of making several quick stops from 50 or so?
I've never bedded pads on a new car or for replacements in my life and had no problems. We have a new Caddy ATS and didn't bed them and it stops just fine.
Is there really a need for bedding? Shouldn't you just avoid quick stops (if possible) for a while, but do nothing else?
Old Sep 27, 2013 | 09:36 PM
MikeERWNC's Avatar
MikeERWNC
First I would go out to my concrete driveway and rub the brake surface in a figure eight pattern on the driveway until the pads are smooth.
Then I would treat them like new pads.
You could also do this on a full size sheet of 80 grit sand paper.
But using the driveway will not cost you the price of sand paper.
I know what cheapazzes some Corvette owners are on this forum.
To Ceramic brake pads
