Introducing DashLogic for C6 Corvette
Old 05-27-2014, 12:12 PM
  #201
0PalmerPerformance
Former Vendor
PalmerPerformance's Avatar
Originally Posted by BigO
I'm having same issue. Updated with the new firmware and still nothing. What's the deal? Replacment units or new firmware coming asap?
Cody from PPE emailed this "We had an issue that we didn't pass the VIN check on 2009 and newer. So we have a period of those that got out the door."
Mine still isn't working after the firmware update.
I believe your hardware is defective. We have a replacement on the way to you already. Sorry about this.
PalmerPerformance is offline
Old 06-01-2014, 09:55 AM
  #202
lokian
lokian's Avatar
Where can I find instructions on adding in analog sensors.. I can read the voltage on them but how do I convert that to actual values I'm looking for.. fuel pressure and plx wideband. Also how accurate is the calculated boost... mine never kicks past 0
lokian is offline
Old 06-02-2014, 08:47 AM
  #203
pikkashoe
pikkashoe's Avatar
Someone else posted in another thread that using the map sensor on the ls3 with the dashlogic, you will only be able to see boost up to 2.7 psi. Is this correct? This thread made it seem that using the dashlogic with the factory map sensor, you would be able to monitor boost with no problem. Monitoring up to only 2.7 psi would not benefit me at all. Trying to figure this out, as I just ordered the dashlogic.
pikkashoe is offline
Old 06-02-2014, 12:59 PM
  #204
0PalmerPerformance
Former Vendor
We are limited by the MAP sensor, however most people change the MAP sensor when adding boost. You are pegging out your factory MAP and your PCM is also not able to see how much boost you have. Once you have a MAP that is not pegged out, we can show as much boost as the MAP can see.
Old 06-02-2014, 01:02 PM
  #205
0PalmerPerformance
Former Vendor
Here is a guide http://www.palmerperformance.com/dow...tion_Guide.pdf
Does your boost PID show vacuum? Do you know what firmware version you are on?
Old 06-02-2014, 03:35 PM
  #206
lokian
lokian's Avatar
yes it shows vacuum... im getting a 2 bar map installed soon so im sure it will change. so if the manufacturer states to use (the slope is 37.5, and
intercept is -18.8.) am i correct to say the expression would be
({pid} * 37.5) - 18.8 = fuel pressure in psi
thanks again.
and plx wideband would be votage * 2 + 10
lokian is offline
Old 06-03-2014, 11:06 AM
  #207
0PalmerPerformance
Former Vendor
thanks again.
Yes, you have it correct for both!
Old 06-13-2014, 05:21 PM
  #208
0PalmerPerformance
Former Vendor
New Firmware available. This firmware has added a PID so you can set an alarm to washer fluid level (for methanol injection cars), added MAF Hz, and Vehicle voltage.
http://www.palmerperformance.com/dow...ware_v1.17.ehx
We have also added several vehicles to our DashLogic lineup, now available
2010-2014 Camaro
2007-2013 GM Truck and SUV (gas and diesel)
2005-2010 Cobalt
2010-2014 Cruze
Old 07-23-2014, 09:45 AM
  #209
cruzc5frc
cruzc5frc's Avatar
I tried scrolling through these pages, but will it display AFR using the front stock O2's or do you a wideband in the rear O2 then wire it up to the device?
cruzc5frc is offline
Old 07-24-2014, 12:53 PM
  #210
0PalmerPerformance
Former Vendor
The factory sensors are a narrowband o2. If you would like a wideband reading, you will need to add a wideband sensor.
Old 07-25-2014, 10:50 AM
  #211
Nick B
Nick B's Avatar
Any chance that you will be adding the ability to roll the windows up and down via the key fob like a window valet?
Nick B is offline
Old 07-26-2014, 03:31 PM
  #212
cruzc5frc
cruzc5frc's Avatar
I didn't see this package until after I purchased the Dashlogic.
http://www.palmerperformance.com/sto...products_id=77
Can I purchase the PLX Wideband Sensor Module (kit) separately, which should include everything I need to get AFR?
Old 07-28-2014, 11:56 AM
  #213
0PalmerPerformance
Former Vendor
You have a PM
Old 07-28-2014, 12:01 PM
  #214
0PalmerPerformance
Former Vendor
Our hardware was not designed with this in mind. We would take too much power to sit on the port active watching for window fob messages. That is not a feature we can add, sorry.
Old 07-28-2014, 03:27 PM
  #215
steeldieman
4th Gear
steeldieman's Avatar
Can I access the gear selected and rev match feature without connecting the module to a p c? 2011 ls3
steeldieman is offline
Old 07-29-2014, 12:25 PM
  #216
0PalmerPerformance
Former Vendor
Yes, it will be on a default page. Just plug into the car and press the lock button until you see gear on the display.
Old 07-29-2014, 12:49 PM
  #217
UrbanKnight
UrbanKnight's Avatar
Rev match????
UrbanKnight is offline
To Introducing DashLogic for C6 Corvette
Old 07-29-2014, 07:15 PM
  #218
franman69
Support Corvetteforum!
franman69's Avatar
I've emailed you guys a couple of times. I've been using the unit for a few months and it's amazingly powerful. I did some updates to my setup and I've found that the odometer PID doesn't want to display anything. I've updated the firmware (in June) and when trying to monitor PID 1011 or 1010 both return 0.0. I've tried programming this in Simple and Advanced mode with no luck.. Any ideas? My trip Odometers display just fine. Thanks!
BTW, I've got a killer HUD/DIC setup for track days showing me everything I really need to know about the car in a glance... I'm showing
Intake Temp/Amb Oil Press
Coolant Temp Oil Temp
and in the DIC all four Tire pressures...
Combined with my Shift-I sequential shift light mounted on the steering wheel upper cover (right below the DIC) it's a solid display for track days and I don't have to worry about paging through anything while I'm on the track.
just what I was looking for. The other pages (3 of them) are setup with more mundane or esoteric things... Then I copied and pasted the first 4 pages to pages 5-8 so I only have to scroll through four pages. That's how I'm using it right now.
franman69 is offline
  #219
franman69
franman69's Avatar
Old 08-12-2014, 02:23 PM
  #220
LethalTT
LethalTT's Avatar
Default Email??
Do y'all answer emails or have a phone I can call? I'm trying to order one of these.
LethalTT is offline
Quick Reply: Introducing DashLogic for C6 Corvette
