Oh I see what you mean now. Well, if you make a Ver. 2 one day, I'd sure like a memory slot so I can datalog without a laptop in the car. I'd just like to reach down, pull out the SD card and take it inside.
To add an update, we added the 60-130mph and 100-200kph timer for ZBADESTZ. We also had another small feature we were working on for quite some time. You can now have control of your NPP by just moving the mirror switch. You have the choice of normal operation, Power Mode which is open NPP, and Quiet Mode which will never open the NPP under any condition. This feature is a free firmware upgrade for all existing customers!!
Right now it is just real time data and alerts while you are driving. If we get enough customers requesting the ability to datalog, we will add the feature. If we do add this feature in the future, it will be a free firmware update for existing customers. You won't need to buy anther device, just a simple update from your computer at home.
Originally Posted by Tropicana
Wouldn't you also need to add a physical memory-card slot?
Originally Posted by PalmerPerformance
From this point, it would require us to redesign the board and enclosure. It is not something we have plans of doing in the near future.
Sorry, I misunderstood, I thought you meant connecting it to a laptop over USB and datalogging through the device.
It has a usb port right? Can't it datalog to a usb thumb drive, (or something similar) then take it to a computer and download? Possible in the future instead of having to add a card slot and avoid current buyers to have to buy another unit?
From: "Once you have flown, you will walk the earth with your eyes turned skyward; for there you have been
Nice job!! Hud + DIC DATA display AND NPP controller!! Just add the window controller to open and close the windows from the RFA / Keyfobs for the 'verts too and you'd have the whole enchilada!!!! Looks like I am going to have an Exhaust Commander Elite for sale soon!!!
We could add the ability to data log to our smartphone app DashCommand over USB through the DashLogic device, that way you would be provided a user interface to set the PIDs you want to datalog. That would be something we could add to the current design. https://play.google.com/store/apps/d...hCommand&hl=en
sounds good!! I don't need data logging but was throwing out an idea because of the requests i read on here, but this is something I may buy as a "toy" in the future great work!
Now add the ability to have aftermarket stereo information display on the hud and you probably would be able to keep the units on the shelf.
For the NPP, Does it work only on factory NPP installed system or would it work also with mild to wild? I have the old vacuum box with remote.
It won't work with any system that isn't doing it like the factory does. You could easily install an NPP module and solenoid and have it working like OEM though.
I don't think we could make the aftermarket stereo thing work, I am not aware that they give any kind of signal out for an external display?
One suggestion for a feature. Some sort of trigger that would automatically roll up both windows. I know that the Window Valet has it for the fobs when the car is parked, but something that would roll the windows up while we are driving would be great!
I would purchase it for that feature alone.
I see the mag shocks on the list. What type of data is available as a result? Since that is constantly updating while driving, I don't understand how that can be useful without logging it for a specific time period. What am I missing?
The display can update at 5 frames per second. You would see a spike if you hit a bump, or see the amount it compresses in a turn. I am not sure what you would do with the data, but it could be interesting to look at?
It's an amazing tool I'll fire off a recorded log soon, once you get this thing you'll never and I mean never drive with out, it's like a drug to see so much! Even shows you EVAP purge what else can you ask for. The window roll up/down would be a cool feature might be possible in the future I'm sure u never know, still it's amazing and so easy to remove and take home.
