With the help of this site, some reading, a wee bit of extra knowledge I have concluded (correct me if I am wrong please) that there is nothing special about the Corvette TPMS system. So, I have found a set of senders for $130 at TPMS Wholesalers that should work just fine and I could get them installed at any tire discounters.
The wheels I bought sat on the shelf in storage for several years so the batteries went dead and that is the reason they won't program. I am not in a position to replace the batteries myself, nor would I for what TPMS Wholesalers charges. A hell of a lot better than the $110 each the Dealer charges.
Thoughts?
Reason: cost of sensors
You will want to verify that they are selling you sensors for a 2005-2009 Corvette, other years or other cars use different sensors.
Some folks have reported frequent problems with aftermarket sensors, but I don't recall which brands.
I got a set of 4 GM sensors for $239.92 + shipping from GM Parts House here, didn't want to be messing around with something that might or might not work.
EDIT:
Corrected price of sensors.
I got a set of 4 GM sensors for less than $200 from one of the GM parts houses here, didn't want to be messing around with something that might or might not work.
That price sounds right. I can't imagine someone paying $340 at a dealer but I guess it can happen.
I hope you will share. I just got a quote from Rxx GMC of $109 each.
When I had my 2013 Camaro SS, I didn't get TPMS's with my new wheels and tires. I just had to live with was the TPMS light on the dash, didn't even notice after a while.
How did we ever live before all these nannies they put on cars now?
Without functioning TPMS active handling will be affected.
The GM OEM sensors are made by Schrader. You can get them online. I think I paid about $42 each and they arrived in 2 days. I had a bad experience when a tire dealer replaced mine with another brand that was supposed to work on Corvettes. I wouldn't use anything but Schrader - it's not worth the hassle if they don't work.
On my 07, when I am driving around and I receive a TPMS warming and it stays there for about 5 miles, then I will check the tire pressure with my tire gage. I believe my TPMS batteries need to be changed, but I have heard it is easier to just buy new ones instead.
good to know that was the issue, but it does seem odd to me. if I recall, the TPMS batteries are supposed to last about ten years. to be all used up by sitting on the shelf, even if after being used on the car, seems unusual.
but I do think getting the right kind/brand (if needed, and it seems like it is needed) for the car is the solution vs. some cutrate brand that may or may not work. after all, one putting on then taking off again to put another set on will eat up any savings.
I don't think TPMS batteries are replaceable. Starting around year eight of service it will be time to plan your purchase of a fresh set of four sensors.
I bought the unit for re-programming the sensors to the car's computer. It's about a two minute job. Takes longer to get the tool out of the drawer. I have two sets of wheels and tires that I swap back and forth so the tool comes in handy. My original tires are eight years old now, so when they are worn out I will install new sensors along with the new tires.
There has been at least one guy here that has changed the batteries in them. The work required to do so is nothing short of more pain in the azz and certainly not worthy of the effort!
This is what the sensors look like. As you can see, they are sealed so you can't change the battery (batteries?) without cutting the case open. If you do cut it open, you might cut into the antenna or some other critical component.
Since these things last 7-10 years, it's really not worth messing with old ones.
