Blinker Replacement Troubles
Old Oct 28, 2013 | 02:02 PM
long_tall_texan's Avatar
long_tall_texan
My passenger side one was extremely hard to get to when installing my switchbacks. I ended up using my Dremel and opening up a little more area so that I could get my man-fingers to the latch. Not to worry, The flap still covers the entire opening. Once I did that, I had no problems. Biggest thing is being able to get your finger in there to depress the socket latch before twisting.
Old Oct 28, 2013 | 06:22 PM
navarrelivin's Avatar
navarrelivin
Cruising
After a little investigation I did find behind the electricians tape there were three splices. I suppose the previous owner had a pigtail mod at some time in the past. The problem is I have no power ahead of the splice either. Is it possible the lighting harness connection at the main body hardness is dirty, loose, etc.? Has anyone seen this problem before? I am guessing to get to that connection for maintenance I must remove the inner fender and brake cooling air duct tube?
