Engine Temp in traffic
Old Oct 19, 2013 | 10:13 PM
tprice's Avatar
tprice
Default Engine Temp in traffic
I was in heavy traffic today, lot of stop and go and VERY slow traffic and noticed my temp pushing the 220 mark
I set the DIC so I could see actual temps and it was at 217, never higher, and when went to normal driving it would drop pretty quick to around 203
Is this ok/normal
LOT of other Vettes in same traffic here this weekend, Pigeon Forge TN for the Corvette Expo.
Old Oct 19, 2013 | 10:35 PM
EVRose's Avatar
EVRose
Mine does that especially with the AC off. It will be at 198° and when I come to a red light it goes to 205-208 before the light turns green again then back down to 198. In heavy traffic I see 217-218°.
Old Oct 19, 2013 | 10:42 PM
Eritosthenes's Avatar
Eritosthenes
No worries. As long as you have a full load of coolant, you're fine. I have an Edelbrock E-Force supercharger with its intercooler radiator mounted in front of the main radiator. On the hottest summer afternoons during the August 2012 midwest drought and heat wave, Red's coolant temps never rose above 225 while stuck in I-64 traffic. Once I started moving again, it quickly fell to 217.
Old Oct 20, 2013 | 02:54 AM
HOXXOH's Avatar
HOXXOH
But then again, your hottest summer afternoons are like an unexpected cool summer day for Phoenix. It's all relative to the ambient temperatures.
Old Oct 20, 2013 | 06:22 AM
Don-Vette's Avatar
Don-Vette
As long as coolant is full and no steam is coming through the hood. No worries if gauge is within normal operating temp. Common sense to know the temp will rise in traffic on a hot day.
Old Oct 20, 2013 | 06:27 AM
Your temps are just fine. Might want to just check and see if the area in front of the radiator is free from leaves and other debris - it's a good habit to check that area every once in a while.
Old Oct 20, 2013 | 07:51 AM
SUB VETTE's Avatar
SUB VETTE
SUBVETTE
You are fine.
Old Oct 20, 2013 | 08:10 AM
1Sikstik's Avatar
1Sikstik
Mine on the hottest day in summer traffic rose to 224 but cooled down once I was moving. Normal is 200 - 210 for me.
Old Oct 20, 2013 | 08:33 AM
tprice's Avatar
tprice
Thanks figured that was ok but wanted to double check
Old Oct 20, 2013 | 08:46 AM
Eritosthenes
True. I graduated from ASU.
Old Oct 20, 2013 | 09:06 AM
dvilin's Avatar
dvilin
Originally Posted by SUB VETTE
You are fine.
Old Oct 20, 2013 | 03:32 PM
LS WON's Avatar
LS WON
Check n clean radiator.
Highest was 230 in gridlock and 192 regular but have since had coolant and waterpump change.
After change 194 to 217..haven't been in gridlock to compare highest temp. of late.
Old Oct 20, 2013 | 03:48 PM
victorf's Avatar
victorf
Personally, I do keep my cars for a long time and not comfortable with heat in the engine bay since it destroys without discrimination.
Even though I removed practically all unnecessary heat traps and did these:
I still was not happy until I did these to allow engine heat to escape in traffic or at highway speed:
In the closed and latched position:
Now I am a happy camper!
To Engine Temp in traffic
