Harmonic balancer
Old Oct 22, 2013 | 09:59 AM
AGC23's Avatar
AGC23
Default Harmonic balancer
How do you know if it's bad and needs replacement. What are the symptoms
Old Oct 22, 2013 | 10:03 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Watch it rotate while you idle the engine. If you see a wobble, it's bad.
Elmer
Old Oct 22, 2013 | 10:04 AM
EVRose's Avatar
EVRose
Search youtube. There are a couple good videos on there of what a bad one looks like.
Old Oct 22, 2013 | 10:08 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Please note that the important part to look at is the belt groove IN the pulley, not the outside faces. GM has a bulletin that discusses this and gives runout limits in the groove, but specifically states that the faces of the pulley are not precisely machined and can not be used to measure runout.
I don't have a copy of the bulletin, Google might find it for you. It's been posted here in the past.
Old Oct 22, 2013 | 10:36 AM
batpig's Avatar
batpig
You might also hear a chirping sound if the balancer is bad.Bat Pig out.
Old Oct 22, 2013 | 10:57 AM
JDP Motorsports's Avatar
0JDP Motorsports
Former Vendor
St. Jude Donor '12
There is always a little movement with the stock damper but if you see excessive movement, belt chirping or the rubber between the inner and outer shell is coming apart you need a new damper. We've replaced a few 08' and 09' units to date but I haven't seen an 10'+ issues yet. Please feel free to call, email or PM me anytime with questions.
Kind regards,
Jordan Priestley
888.308.6007
Old Oct 22, 2013 | 11:26 AM
ktaustins's Avatar
ktaustins
2025 C8 of the Year Finalist - Modified
Look at the tensioner if its jumping much (my be > 1/8"). All HB may wobble a little and tensioner jump small amount, normal
2001 70k replaced HB and it is took out alternator, tensioner, idle pulley.
2008 65k caught it early only replaced HB.
I am 51 and never replaced an HB til I got a vet? I really like my vet an good thing or I would have second thoughts.
Old Dec 23, 2013 | 06:36 PM
Jumper11's Avatar
Jumper11
Default 2002 HB concerns.
I'm not sure mine is wobbling. I looks like it's wobbling but when I hold a screw driver against the HB when the engine is running the screw driver doesn't wobble. My tensioner tab moves about 1/8 to 1/4 when running. If anyone knows a good video to share that would be great. If I do it my self I got to remove the steering rack right? Need info on that too. Thanks in advance
Old Dec 23, 2013 | 06:44 PM
smurfkiller's Avatar
smurfkiller
yes steering rack has to be moved to get the balancer off. not a hard task certainly alot easier if you have a lift.
Old Dec 23, 2013 | 07:08 PM
Mad*Max's Avatar
Mad*Max
Old Dec 23, 2013 | 08:58 PM
xxvetteman's Avatar
xxvetteman
Mine started off sounding like a small bird chirping under the hood and ended up sounding like a flock of birds!!! Ha ha! Had it fixed in the fall.
Old Dec 23, 2013 | 09:53 PM
SLPRC5's Avatar
SLPRC5
My '05 started with the "bird chrip" when I had it changed the HB moved back towards the engine putting a wear in the oil pan and timing chain cover..I was lucky it didn't wear into them that they would have to be replaced or fly apart and caused other amage..
Old Dec 23, 2013 | 10:01 PM
RHFD122's Avatar
RHFD122
TSB 05-06-01-001A (Feb 8, 2005)
Check Gages Light, Battery Voltage Low, Accessory Drive Belt Slipping or Missing (Install Washer from WPC and Crankshaft Balancer) #05-06-01-001A - (Feb 8, 2005)
Table 1: Warranty Parts Center Parts
Table 2: GMSPO Parts
Table 3: Part Request Form -- Warranty Parts Center
2005 Chevrolet Corvette
with 6.0L Engine (VIN U - RPO LS2)
Built Prior to VIN Breakpoint 55111039
This bulletin is being revised to include VIN breakpoint and additional inspection information. Please discard Corporate Bulletin Number 05-06-01-001 (Section 6 -- Engine).
Condition
Some customers may comment on the Check Gages Light or the Battery Voltage Low indicator coming on. Additionally, some customers may comment on the accessory drive belt either slipping or being missing.
Cause
The crankshaft balancer bolt may have become loose.
Correction
Install a new crankshaft balancer pulley, washer and a new balancer pulley bolt using the following procedure:
Disconnect the negative battery cable at the battery.
Remove the air duct (6).
Remove the radiator support.
Remove the accessory drive belt.
Disconnect the generator.
Remove the generator bolts and generator.
Disconnect the steering intermediate shaft at the steering gear.
Install the lifting links to the engine (J 41798).
Install the fixture for lifting the engine (J 41803).
Hoist the vehicle.
Remove the front wheels.
Loosen the motor mounts.
Install the leaf spring fixture (J 33432-A).
Disconnect the tie rods (5) from the steering knuckle (4).
Disconnect the speed sensor.
Remove the lower ball joint nut and disconnect the lower control arm from the knuckle.
Disconnect the bottom shock absorber bolts.
Disconnect the ABS module bracket bolts.
Disconnect the stabilizer shaft insulator clamp bracket bolts and shaft.
Disconnect the cooler line bolts to the engine cradle.
Install a suitable jack under the cradle.
Remove the cradle nuts.
Lower the cradle.
Remove the A/C belt.
Disconnect and remove the starter.
Install the flywheel holding fixture J 42386-A.
Remove the cooling fan bolts and fan assembly.
Scribe or mark balancer orientation.
Remove the crankshaft balancer bolt (139). Do not discard the crankshaft balancer bolt. The balancer bolt will be used during the balancer installation procedure.
Use the J 41816 (1) and the J 41816-2 (2) in order to remove the crankshaft balancer.
Place the old and new balancers on the bench and orient them the same way (i.e. face up with a weight balance hole at 12 o'clock). Scribe/mark the new balancer in the same location as the old balancer. Do not transfer weight pins on manual transmission equipped vehicles. Most vehicles will be balanced without the use of any additional weight pins. Because some balancers may have spun on the crankshaft, transferring weight pins to the same position would produce a random imbalance. For vehicles that exhibit imbalance (very rare), contact Technical Assistance.
Inspect for the following conditions:
• Metal transfer to the crank post. Replace the crankshaft if metal has been transferred to it or it is damaged.
• Metal transfer or damage to the timing chain sprocket face. Replace the sprocket if either condition is present.
• Verify that the bolt does not bottom out in the crank post.
Install the new washer onto the crankshaft and push into place by hand.
Install the new balancer paying attention to line up the scribe mark.
Use the J 41665 in order to install the balancer.
Assemble the threaded rod, nut, washer and installer. Insert the smaller end of the installer into the front of the balancer.
Use a wrench and hold the hex end of the threaded rod.
Use a second wrench and rotate the installation tool nut clockwise until the balancer is started onto the crankshaft.
Remove the tool and reverse the installation tool. Position the larger end of the installer against the front of the balancer.
Use a second wrench and rotate the installation tool nut clockwise until the balancer is installed onto the crankshaft.
Remove the balancer installation tool.
Notice: Failure to apply proper torque to the old balancer bolt may result in the balancer not being fully seated. This could lead to failure of this joint in the future.
Install the old balancer bolt and tighten.
Tighten
Tighten the old balancer bolt to 330N•m(240 ft. lb).
Important: The nose of the crankshaft should be recessed 2.4-4.48 mm (0.094-0.176 in) into the balancer bore.
Remove the old bolt and measure the hub to crankshaft distance.
Coat the three to five threads of the new bolt with thread locker (LOCKTITE™ 272) P/N 12345493 before installation.
Notice: Be sure to follow the torque procedure for installing the new crankshaft bolt. Use of impact tools, or not using torque and angle method will result in joint failure.
Install and tighten the new crankshaft bolt.
• Tighten the crankshaft balancer bolt a first pass.
Tighten
Tighten the crankshaft balancer bolt a first pass to 50N•m (37 lb ft).
Put a paint stripe on the bolt running from the 12 o'clock to the 6 o'clock position in order to verify the correct torque requested in the next step.
• Important: When tightening for the second pass, a minimum torque of 320 N•m (236 lb ft) should be observed. If this torque is not achieved, the bolt should be replaced.
Tighten the crankshaft balancer bolt a second pass.
Tighten
Tighten the crankshaft balancer bolt a second pass to 140 degrees using the J 45059.
Important: Recheck the position of the previously painted stripe to assure 140 degree rotation. Achieving the correct torque angle is critical to the success of this repair. Over-torquing or under-torquing the joint will result in an unsatisfactory repair.
Remove the J 42386-A Flywheel Holding Tool.
Install the starter and bolts. Tighten the starter bolts.
Tighten
Tighten the starter bolts to 50 N•m (37 lb ft).
Important: Orient the purple lead wire to the 10 o'clock position when installing.
Connect the starter wiring.
Install the starter motor S terminal washer and purple lead wire (1).
Install the S terminal nut (2) and tighten.
Tighten
Tighten the S terminal nut to 4 N•m (35 lb in).
Important: Orient the gray and rust harness leads to the 6 o'clock and 7 o'clock position.
Install the gray and rust harness leads to the solenoid.
Raise and align the cradle.
Install and tighten the cradle nuts.
Tighten
Tighten the nuts, using hand tools only, to 110 N•m(81 lb ft).
Install and tighten the engine mount nuts.
Tighten
Tighten the nuts to 65 N•m(48 lb ft).
Install the A/C belt.
Install the cooler line bolts.
Install the fan shroud assembly and bolts.
Tighten
Tighten the bolts to 5 N•m(44 lb in).
Position the stabilizer shaft and install insulator clamps and bolts.
Tighten
Tighten the stabilizer shaft insulator clamp bolts to 58N•m (43 lb ft).
Install the tie rod to the steering knuckle.
Install the outer tie rod end stud nut to the outer tie rod end stud and tighten .
Tighten
Tighten the outer tie rod end stud nut to 20 N•m(15 lb ft) to seat the stud.
Turn the nut an additional 160 degrees.
Check for the outer tie rod end stud nut for a minimum final torque of 45 N•m(33 lb ft).
Install the lower ball joint to the steering knuckle.
Tighten the lower control arm ball joint stud nut.
Tighten
Tighten the nut to 20 N•m (15 lb ft) to seat the ball joint stud.
Turn the ball joint stud nut an additional 210 degrees.
Check the ball joint stud nut for a minimum final torque of 55 N•m (41 lb ft).
Install the shock bolts and tighten.
Tighten
Tighten the shock absorber lower mounting nuts to 28 N•m (21 lb ft).
Repeat tie rod, lower ball joint and shock for the other side.
Install the tires and lug nuts.
Important: Tighten the nuts evenly and alternately in order to avoid excessive run out of the tire and wheel assembly.
Using the J 39544-KIT , tighten the wheel nuts in the appropriate sequence shown.
Tighten
Tighten the nuts in sequence to 140 N•m(100 lb ft).
Remove the support jack.
Remove the Leaf Spring Compressor (J 33432-A).
Lower the vehicle.
Remove the engine support fixture.
Remove the engine support links.
Install the upper radiator support and tighten the bolts.
Tighten
Tighten the bolts to 9 N•m (80 lb in).
Install the coolant and EVAP lines to the fan shroud.
Install the engine cover and oil fill cap.
Install the intermediate shaft.
LOCTITE™ the steering intermediate shaft bolts and install.
Tighten
Tighten the lower coupling retaining bolt to 34 N•m (25 lb ft).
Install the generator and tighten the bolts.
Tighten
Tighten the generator bolts to 50 N•m(37 lb ft).
Connect the generator wiring.
Tighten
Tighten the battery feed cable nut to 13 N•m(10 lb ft).
Install the new accessory belt.
Install the air duct and box.
Connect the battery cable to the battery.
Perform a crankshaft variation relearn procedure.
Parts Information
Order a washer from the WPC using the form at the end of this bulletin. Fax the request form to the WPC at 248-371-0192, or E-mail to warrantypartscenterusa@gm.com .
All other parts should be ordered from GMSPO. Use the normal ordering process for all orders.
Warranty Parts Center Parts WPC Part Number
Description
Qty
305
Washer, Crankshaft Balancer
1
GMSPO Parts Part Number
Description
Qty
12557840
Bolt, Crankshaft Harmonic Balancer
1
12583637
Balancer, Crankshaft Harmonic
1
12579229
Belt, Water Pump, Power Steering and Generator
1 as req'd
12579228
Belt, Air Conditioning Compressor
1 as req'd
Parts are currently available from GMSPO.
Warranty Information
For vehicles repaired under warranty, use:
Labor Operation
Description
Labor Time
J0710
Pulley, Crankshaft Balancer - Replace
2.3 hrs
Old Dec 24, 2013 | 10:12 AM
RoadkingC6's Avatar
RoadkingC6
one way to check is to grab the balancer with both hands and see if you get a lot of physical movement while applying push and pull pressure from left to right.
Old Dec 24, 2013 | 11:20 AM
EVRose's Avatar
EVRose
That would be kind of hard to do with it still on the car.
Old Dec 24, 2013 | 07:14 PM
CMY SIX's Avatar
CMY SIX
Elmer
oh really, who say's it's going to run in a perfect circle? even my SFI rated HB moves, I doubt you can tell us what it does?
Old Dec 24, 2013 | 07:15 PM
CMY SIX's Avatar
CMY SIX
05's had a recall for theirs
To Harmonic balancer
Old Dec 24, 2013 | 07:38 PM
EVRose's Avatar
EVRose
Nope. There was a TSB and that was for the bolt coming loose on early vin's. No TSB or recall on the balancer although there should be.
Old Dec 24, 2013 | 09:41 PM
torquetube's Avatar
torquetube
Yours may get worse someday, but what you describe isn't bad. Plenty of C6s left Bowling Green just like that, and are still just slightly wobbling tens of thousands of miles later.
Old Dec 24, 2013 | 10:32 PM
Saluda's Avatar
Saluda
When you stop at a red light in town and your Vette starts chirping so loud you duck down in the car to hide because you are embarrass, it might be time to change that Harmonic Balancer.
