Confused
Old Nov 2, 2013 | 01:38 PM
Cor CP 21's Avatar
Cor CP 21
Default Confused
Hey guys,
I have a Pioneer Nav installed in my car with backup camera.. Everything was working... when I put the car in reverse, the nav switches to the backup camera. All of a sudden, two weeks ago.. the camera does not show up anymore. I have looked though many forums posts and I saw that many people changed their reverse lamp switch.. So I went ahead and ordered that switch and changed it out. Still no camera when I put the car in reverse. I have checked the fuses in the passenger footwell and under the hood.. I can manually put the camera on through the nav screen so I know the camera is working.. but when I put it in reverse, no backup screen.. Any ideas?
Old Nov 2, 2013 | 01:59 PM
jwf's Avatar
jwf
Hummmm.... sounds like the head unit and camera work and the signal connections are ok. So it does sound like something on the reverse-sensing circuit. If the switch is ok then maybe a connection in that circuit somewhere????
Old Nov 2, 2013 | 02:01 PM
harveyjl's Avatar
harveyjl
Not the head unit or camera, check the connection where the camera gets the signal from the car when it is shifted into reverse.
Old Nov 2, 2013 | 02:02 PM
Cor CP 21's Avatar
Cor CP 21
also my reverse lights do not come on.. sorry, I forgot to mention that
Old Nov 2, 2013 | 02:08 PM
harveyjl's Avatar
harveyjl
That's the problem, I bet!! The camera gets the signal to turn on from the lights, fix the lights and it will fix the camera!
Old Nov 2, 2013 | 02:09 PM
harveyjl's Avatar
harveyjl
or the camera gets the signal from the same spot the reverse lights do. and to get one working (reverse camera) you must first fix the other (reverse lights)
Old Nov 2, 2013 | 03:01 PM
sevinn's Avatar
sevinn
St. Jude Donor '14, '16
Check and make sure that your reverse lamp relay is working. You should be able to hear it click in the passenger footwell of your car when you put it in reverse. It is in the fuse panel in the passenger footwell.
You should be able to check the diagram to see which one it is; it may be under an additional cover.
Old Nov 2, 2013 | 05:16 PM
NY3quartrs5-oh's Avatar
NY3quartrs5-oh
check the bulbs, check the relay, check the piece you changed to make sure that is working.
Old Nov 3, 2013 | 01:15 AM
Cor CP 21's Avatar
Cor CP 21
so there is another reverse lamp relay in the passenger footwell for reverse lights?
Old Nov 3, 2013 | 01:55 AM
sevinn's Avatar
sevinn
Well there's one .
It's under the black block with a nut in the middle; never removed that myself but it's the one on the left under there.
Also check fuse #5 under the hood
Old Nov 3, 2013 | 02:20 AM
Cor CP 21's Avatar
Cor CP 21
Well there's one .
Also check fuse #5 under the hood:
ahh.. ok I can check tomorrow if it is clicking.. is there a part number for this relay, just in case this thing is the reason the backup lights are not working?
Old Nov 3, 2013 | 02:41 AM
sevinn's Avatar
sevinn
Looks like 12177236 according to gmpartsdirect but chances are you could take the relay to a parts store and they would have an equivalent.
Old Nov 4, 2013 | 08:03 PM
Cor CP 21's Avatar
Cor CP 21
I took apart that plastic cover.... I see a bunch of wires going into a plastic panel and then the panel goes into a pin out in the car foot-well.... any ideas where the actually relay is?
Old Nov 4, 2013 | 09:02 PM
J Christensen's Avatar
J Christensen
Old Nov 6, 2013 | 11:14 AM
sevinn's Avatar
sevinn
Wow I just assumed there based on the diagram was a relay there; can definitely hear one clicking in my car when I go into reverse.
Sorry I've never had that area apart.
Old Nov 6, 2013 | 06:45 PM
Cor CP 21's Avatar
Cor CP 21
hmm.. hopefully somebody chimes in with a solutions.. I am out of answers...
Old Nov 6, 2013 | 08:11 PM
NY3quartrs5-oh
I didn't mention this before because the reverse lights aren't working either, but i had the same problem a few weeks ago with my kenwood and backup cam. Mine happened after battery disconnect and i could manually put the camera on but in reverse didn't come on. Finally I got it working after recalibration of the camera in the head unit settings. The fact that your reverse lights are out make me think it's something else, but a recalibration is simple if you want to try....
To Confused
Old Nov 6, 2013 | 08:17 PM
NY3quartrs5-oh
PS did you change both bulbs to rule that out? Don't think the cost should be too bad for two bulbs and it's about a 10 min job
Old Nov 7, 2013 | 12:57 AM
Cor CP 21's Avatar
Cor CP 21
so if the bulbs were out, the reverse signal wire would not work? I am just wondering, since I do not know..
Old Nov 7, 2013 | 08:52 AM
RoadkingC6's Avatar
RoadkingC6
if the bulbs light up with the car in reverse, that would tell you that the fuses are good and the green wire used for the reverse lights has power on it, something else I just noticed fuse #5 says StopLamps/Back-up lamps so if you have stop lights you have power.
