Dreaded Clutch Issues
Washed, master blasted it dry and got back in to pull back in garage---clutch goes to the floor and doesn't come back up. I can pull it up and it 'snaps' back into place, but next press it goes to the floor and stays. So odd it would be fine backing out and 30 minutes later it's broken.
I turned it off, left in neutral and pushed into garage. Today I bought clutch and brake fluid from Chevy dealer and used the Ranger Protocol to change the fluid. It took a few iterations but the fluid is now clean, but the clutch is doing the same thing.
From everything I've seen, it's now down to a trip to the dealer; but I'm hoping a last-ditch post here may bring out a few other ideas to try....is there any mechanical linkage or spring or something else I can check on?
Thanks guys and gals!
You said it "snaps back up" when you manually pull it up. That indicates the spring is still functioning.
From what you've said sounds like a bad master cylinder. If it is, it's a relatively easy replacement.
And only to give you a little more to think about here's what GM said about that basic issue:
http://forums.corvetteforum.com/kens...al-effort.html
The spring and all clips and brackets appear to be in proper position and working order. When pushing down, the pedal has no resistance past what the spring provides---no hydraulic resistance. And then there is no upward force on the pedal that would push it back to normal "up" position.
So, yeah, by everything I've read it's a bad MC. Wanted to make sure I wasn't missing something easy. Hoping against hope I guess...
I'm pretty much down to debating whether to install a new MC myself (and maybe use aftermarket) or let the dealer monkey with it.
Thanks again for the reply, I appreciate it.
